Thread: Help me "reasonable-ize" my daily driver mod list.
Results 1 to 17 of 17
  1. #1 Re: Help me "reasonable-ize" my daily driver mod list.
    new britain, ct
    personally, i think you should get headers.
    you will be able to run more timing, and with the 3.4 pulley you will have so much more flow up top.
    the route i would take is...3.4 pulley, rockers, headers. ive seen those setups go 230-250 whp.
    without headers you leave a lot of power out on the table for not too big a price.
    then you can intercool down the line if you want moar powa.
    07 Black GXP.
  2. #2 Re: Help me "reasonable-ize" my daily driver mod list.
    Quote Originally Posted by rafadavidc View Post
    This sounds like a huge project. Except for the rear manifold, I'm pretty sure I can get to everything in the ZZP list with the engine sitting in the engine bay and the car sitting on the ground on jack stands. Am I wrong? I'm hoping for a driveway-type project here.
    You can do a cam in the driveway as long as you have two jack stands.
    Quote Originally Posted by ctracer View Post
    Requires fabrication skills.
    OP?
  3. #3 Re: Help me "reasonable-ize" my daily driver mod list.
    Mar 2013
    Milwaukee
    I'm guessing wheel well, then. Link to procedure?
    OP?
    I am not a welder, nor do I have access to such equipment. However, it's not obvious to me what in the post you quoted would require such skills. Could you elaborate?
  1. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  2. Front Driver Side "Clunk" Mystery. Any ideas?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2011, 03:41 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
