Thread: Headers
Results 1 to 20 of 30
  1. #1 Headers
    SE Level Member CountryBoy's Avatar
    Jan 2013
    Lima Ohio
    I'm going currently getting the ball rolling on swapping my cars pulley back to stock right now but I want to start getting the ball rolling on supporting mods for the car so i can eventually swap back down to the smaller pulley. I think my first step will be headers so i need opinions,what are some good brands of headers out there that are high performance yet cheap??
    Got Boost?
  2. #2 Re: Headers
    The Boss Iceman6669's Avatar
    Jun 2011
    right now SSACs are the best bet.. Pacesetters are fairly cheap too but might require some added work.
    2011 F-150 Yote powered
  3. #3 Re: Headers
    Jan 2013
    Lima Ohio
    how much are SSAC's for a set??
    Got Boost?
  4. #4 Re: Headers
    Jun 2011
    $225 shipped IIRC
  5. #5 Re: Headers
    Nov 2011
    NY
    Pacesetters FTW!!!
    Do search and do some homework, search google and you'll find prices, availability is another issue. I have pacesetters and love em, no issue with installation or otherwise.
  6. #6 Re: Headers
    Jun 2011
    I have heard sometimes the collector leaks on the Pacesetters and has to be welded closed... But I went with Speed Daddys before they were a BAJILLION dollars
  7. #7 Re: Headers
    Nov 2012
    Madison
    HEADER - STAINLESS STEEL - 97-03 PONTIAC GRAND PRIX 3.8L V6
    Just checked speed daddy site and it said they are in stock@239.99 go figure
  8. #8 Re: Headers
    Nov 2011
    NY
    Quote Originally Posted by Iceman6669 View Post
    $225 shipped IIRC
    Omg ... Pacesetters 2-3x that, so can't compete (on price) lolz
  9. #9 Re: Headers
    Jan 2013
    Lima Ohio
    so either SSAC or pace setters are the way to go right now,once i get the money in hand I want to get a set so i can start to work towards getting my car set to run the 3.4 pulley that I'm pulling off my car because some idiot before me decided a 3.4 pulley with intake and exaust was a good idea
    Got Boost?
  10. #10 Re: Headers
    Jun 2011
    LOL... Speed Daddys are good too if you can get them for around the same price as SSACs.
  11. #11 Re: Headers
    Jan 2013
    Lima Ohio
    well when i get the car running 100% after i get the pulley back to stock and fix whatever else i find wrong with the car I'm throwing a set of headers on it to get the ball rolling. I eventually want to run low 12's in the 1/4 mile with the car but that goal is a long ways away
    Got Boost?
  12. #12 Re: Headers
    May 2008
    Schuyler, NE
    I would try to avoid pacesetters. They are difficult to seal up the y-pipe.
    Otherwise, TOG's, ZZP, WBS are all good headers. SSAC, XS Power, and Speed Daddy will all require modifications before they are issue-free.
  13. #13 Re: Headers
    Jan 2013
    Lima Ohio
    what about SLP performance??
    Got Boost?
  14. #14 Re: Headers
    Jun 2011
    Speed Daddys and SSACs are the same thing as SLP....Plus there is really no need to spend a lot of money on top dollar headers if your not going to MAX power(i.e. Ported Heads)
  15. #15 Re: Headers
    Jan 2013
    Lima Ohio
    well the thing is I eventually want to go that far with the car,I just want to take it a step at a time
    Got Boost?
  16. #16 Re: Headers
    Jun 2011
    If you have ported heads then I would recommend the bigger primary headers... And if you plan on doing that then I guess the choice is yours...
  17. #17 Re: Headers
    GT Level Member Shiftingshaddow's Avatar
    KC
    i'm looking at headers and i'm seeing things like, cut and weld, pound firewall in to fit, clamps bad, leaky flexpipe......
    why make headers that dont fit the fit the car? why not provide good clamps?
    the clamps i guess is something i can work with, but not the other stuff.
    so what has to be done to get the speed daddys or ssacs to work? are they straight bolt in? do you use factory gaskets? i have 2001 gtp
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  18. #18 Re: Headers
    On my sd's I had to beat the firewall in to clear the o2. On a set of ssac's I installed the crossover didn't line up.
  19. #19 Re: Headers
    Jun 2011
    SDs use factory gaskets, new clamps, and you might have to pound firewall to fit DP.
  20. #20 Re: Headers
    KC
    so what did you wind up doing for the crossover? and when did you install? is there a chance they redesigned? i don't imagine the setup in the 98 and 01 is too different as far as space and exhuast are concerned. but maybe
  1. Headers
    By JonnyGrandPrix in forum General Grand Prix Discussion
    Last Post: 03-08-2012, 09:48 AM
  2. Anyway around headers?
    By Thexissilent in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2011, 08:27 PM
  3. headers on a l36?
    By mezzoni in forum Engine
    Last Post: 05-11-2010, 09:59 PM
  4. headers
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 01:36 AM
  5. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
