Thread: Which t-stat should I get?
Results 1 to 20 of 41
  1. #1 Re: Which t-stat should I get?
    PA
    Does anyone know why they want to get a cooler t-stat? Do you know why you want your engine cooler?
    The entire colder t-stat idea is to prevent KR. The colder the engine is, the less KR you should get. But if you mod correctly and tune your car, you should not have any KR to contend with. Thus you should be able to run a stock t-stat and get better mileage and better performance.
    My personal opinion is stick with a stock temp t-stat.
    2001 GSE
  2. #2 Re: Which t-stat should I get?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Zef_66 View Post
    Excellent point. Most folks do not want to take the time to "think" about what they are doing to their car, and why.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Which t-stat should I get?
    you do know cars are faster when the engine is colder, right?
  4. #4 Re: Which t-stat should I get?
    Banned
    oswego
    It's simple, the colder the air getting into the cylinder the better. It might be minimal gains but some people take what they can get. How many of these gtp's around here are honestly modded correctly? I can tell you pretty much everyone has kr, so that'll never happen. Everyone thinks it's ok to have it... it's a $10 blanket imo worth every penny.
  5. #5 Re: Which t-stat should I get?
    Waynesboro, PA
    Only if the car is set up for it, and even then engines are typically most efficient right around 200°F.
  6. #6 Re: Which t-stat should I get?
    Banned
    oswego
    Quote Originally Posted by JoshMcMadMac View Post
    Efficient for what? Gas mileage? That's pretty much it. 14.7 is a perfect burn, but not for wot it isn't, unless you want the perfect burn hole in your piston lol.
  1. 180* T-stat
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 10:30 PM
  2. 180* T-stat
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2008, 06:03 PM
  3. t-stat ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-29-2008, 11:30 AM
