I installed an intake earlier today to try and make to supercharger louder. But the engine is louder and the supercharger is barely louder. Not sure if there's something wrong. Can barely hear the sc
video? pics of the intake?
Hitting the gas hard enough?
so are most others. make a video of it maybe we will see somethig you did wrong
not sure if your hitting the gas hard enough, otherwise there is definitely an issue.
yeah.................................. wheres bill we need bill
seems like bbp
its that black cicle thing with a metal lever arm and a vacuum line coming off of it
This
Yeah you prob gotta get the rpms a little higher. Mine idling or anything under 2-2.5 rpms dont whine
Idling the blower doesn't do jack **** unless you hit hard enough on the gas so it revs up to above 3k.
Have you driven it since you put it on?
Yup, you need to go into boost to really hear it.
There has to be a load on the engine to get boost, ie whine. The only way you will get that sitting still is if you, hold the brake, put the car in gear and smash the gas while still keeping the brake held.
It's louder when I'm moving and get on it. But even when I'm getting on it, it's not as loud. When I first bought it 2 years ago it was loud but after I replaced to upper and lower intake mani gaskets it hasn't been as loud since.
