Thread: supercharger 3.4 pulley help
Results 1 to 20 of 29
  1. #1 supercharger 3.4 pulley help
    SE Level Member beattie's Avatar
    Mar 2012
    bryan,oh
    ive looked all over and wanting to get a little bit more advise before i do anything....im lookin to put a 3.4 pulley on my 97 gtp but dont have anything done yet whats the bottom i can have done b4 puttin this on....im gona order a pcm from 3800 performance... one place was saying all i have to do was take out ubend and get colder plugs but find a lil hard to believe...and if i get a 3" down pipe what else has to go with it dont really have much money to spend at the moment tryin to get bye will the least i can for now thanx...
  2. #2 Re: supercharger 3.4 pulley help
    Mar 2012
    bryan,oh
    oh ya and it said 180 tstate and i do have cai already by the way
  3. #3 Re: supercharger 3.4 pulley help
    North Jersey
    if your trying to save money, get Speed Daddy headers off ebay for $200 +/- off ebay.
    lots of guys are using them, they'll work just fine.
    get the colder plugs, then get the pcm setup for it.
  4. #4 Re: supercharger 3.4 pulley help
    antioch ill
    Those headers are currently ~$500
  5. #5 Re: supercharger 3.4 pulley help
    North Jersey
    your kidding.
    my mouth is stuck open.
    well its a good thing i'm too low for them to work anyways.
  6. #6 Re: supercharger 3.4 pulley help
    antioch ill
    Nope 238 one day near 500 the next and a couple days later out of stock
  7. #7 Re: supercharger 3.4 pulley help
    Quote Originally Posted by Matt LE-FAG Palm View Post
    Wow just seem that. Glad I have my set
    04 Comp G.
  8. #8 Re: supercharger 3.4 pulley help
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Jut went to eBay to check it out myself very true can't believe how much they upped the price and only on the 3800 headers nothing else. The company is located about 20-30m away from where I live so pretty close. Might have to call them or drop by and check to see why the huge price difference.
  9. #9 Re: supercharger 3.4 pulley help
    North Jersey
    who knows where these are actually coming from, so maybe theres a company feud issue?
  10. #10 Re: supercharger 3.4 pulley help
    Willoughby, Ohio
    check out the DNA motortuning ones on ebay also...they too are SLP knockoffs i got mine for 200ish
  11. #11 Re: supercharger 3.4 pulley help
    If you don't have much to spend save your money until you can buy headers
  12. #12 Re: supercharger 3.4 pulley help
    Link in my signature.
    Read; research.
    Your post basically shows you really haven't looked, or if you have...didn't find any info worthwhile.
    Also; if you don't have the money to do it correctly, then don't do it until you can afford it. Because when you spend every last penny on go fast parts and then you break something...you'll but up sh1t creek with no paddle halfway to BFE.
  13. #13 Re: supercharger 3.4 pulley help
    Nov 2011
    NY
    Its like working on the house... Figure what you want to spend, but save 2x as much, cause that's what it'll wind up costing ya'.
    Lol... Just sayin!
    Best to be prepared!!
  14. #14 Re: supercharger 3.4 pulley help
    Time to buck up and buy ZZP's.
  15. #15 Re: supercharger 3.4 pulley help
    I'd rather run PEM's and a 3" downpipe then.
  16. #16 Re: supercharger 3.4 pulley help
    Quote Originally Posted by blueguy91 View Post
    stock manifolds and a turbo.
    mucho better.
    But I think the OP might consider a PLOG with the downpipe.
  17. #17 Re: supercharger 3.4 pulley help
    I live here. TLSheff's Avatar
    Pontiac Performance Racing Products for International Sales from SSAutochrome Inc.
    Same as the Speed Daddy off Ebay, $175.00 + 50.00S&H. Might want to call or email and make sure they still have stock, if they do they are just as good as the SDs.
    The flex pipe is single wall and kind of weak, may consider a zzp dual wall flex to have welded in place later on, and you will want better clamps than the ones they provide if you don't want any leaks. Otherwise a good set of cheap headers.
    http://www.grandprixforums.net/97-03...ems-60802.html
    http://www.grandprixforums.net/safel...0-a-67580.html
    http://www.grandprixforums.net/ultim...0-a-49055.html
    Headers, Intake, tune, 3.5/3.4 pulley... winning for cheap.
    But you have to have flow, more air in without more air out means something somewhere is going to break under pressure.
  18. #18 Re: supercharger 3.4 pulley help
    Mar 2012
    bryan,oh
    if i bought this.... ZZPerformance - Stage 2 Performance Package #ZZ-STG2PP what else would i need or would that be good enough to get bye on without hurting anything
  19. #19 Re: supercharger 3.4 pulley help
    Unless you like the look of this, listen and learn.
    Don't make us say we told you so. Follow the safe way to do it.
  20. #20 Re: supercharger 3.4 pulley help
    Do as we say. Save money. Profit.
    If you do that, it still won't flow well enough, unless you like the idea of chipped pistons. Then by all means.
  1. Supercharger oil on pulley.
    By Deno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 07:27 PM
  2. New supercharger pulley
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-24-2008, 12:01 AM
