Thread: EGR delete
Results 1 to 20 of 34
  1. #1 EGR delete
    I'm getting ready to install my headers and I figured i'd delete the EGR while i was at it. I know until i tune my mpg will be a little lower but is there any other down sides? Thanks
  2. #2 Re: EGR delete
    leaks and a few codes.
    just make sure you seal it up good.
  3. #3 Re: EGR delete
    Jul 2011
    Edmonton, AB
    I think EGR delete will increase cylinder temps and is recommended against without an intercooler. I may be wrong.
  4. #4 Re: EGR delete
    well because since now that the exhaust gases are no longer there, more air and fuel are now taking up that space and making a smidge more heat, but if you got headers it can get that heat out faster with no problems. I have zero issues with having no egr on my car and wouldnt think twice about it again.
  5. #5 Re: EGR delete
    why delete it if you dont have an IC? there really isn any gain from it that I know of...
  6. #6 Re: EGR delete
    GT Level Member WHT98GTP's Avatar
    Monroeville
    Quote Originally Posted by gtpsleeper View Post
    I think one benefit IMO is keeping the intake system cleaner... Your dumping all that carbon and exhaust in there, it cakes up everything... Me personally, I love keeping everything nice and spotless... :-)
    *2002 Buick LeSabre Custom* Bronzemist Metallic * SS Headers *4" FWI*
  7. #7 Re: EGR delete
    I reinstalled it i figure i can delete it down the road if i want to.
  8. #8 Re: EGR delete
    Bunnell, FL
    way to let teh sheep change your mind
    I'm a Sex Offender
  9. #9 Re: EGR delete
    EGR sucks.
    Emissions are dumb and are for hippies.
    Take it off...let your engine enjoy fresh air...not recycled hot exhaust crap air.
    Which is the reasoning behind gunked up, carbon filled throttle body issues. It costs 2 cents and some RTV.
  10. #10 Re: EGR delete
    michigan
    So being new and uneducated on this subject, what does deleting it do? More power? More efficiency? I've heard about it and was just wondering.
  11. #11 Re: EGR delete
    Quote Originally Posted by twol8uluz View Post
    Let me google that for you
  12. #12 Re: EGR delete
    michigan
    Cool, thanx. Lol
  13. #13 Re: EGR delete
    I don't get to be a smartass very often, but when I do...I use LMGTFY
  14. #14 Re: EGR delete
    **** hippies....
  15. #15 Re: EGR delete
    EGR sucks.
    I used it to pass my e-test.
    Almost zero emissions.
  16. #16 Re: EGR delete
    SE Level Member ejechtion54's Avatar
    Ft. Wainwright
    Where might I be able to find the block off plate for the EGR valve. I know ZZP has a block off plate for the exhaust hose for the EGR, but is there a plate for the actual EGR itself?
    Who ever said "Out with the old and in with the new."?
  17. #17 Re: EGR delete
    The egr goes away you need two block off plates one goes on the exhaust and one goes on the intake manifold under the tb
  18. #18 Re: EGR delete
    Quote Originally Posted by ejechtion54 View Post
    Yeah...you use the factory ones after you cut off the gold factory tubing from each bracket...
  19. #19 Re: EGR delete
    Pshhh.... I don't have emissions tests here so eat it.... Lol in Kansas we don't care!
  20. #20 Re: EGR delete
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I used the two old tabs and welded the holes shut.The only tricky part it grinding the weld flat.My main reason for the delete was not having that ugly a$$ egr solenoid
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  1. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  2. delete please
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 12:57 AM
