Ok so this has been quite an ordeal for me. I did a top swap and shortly after it started to stall out randomly on me. At first I had no tach ans the tcs light came on. So naturely I replaced the cps, which eventually solved that. But the car still would stall out on me randomly and be a ***** to get to start back up. One time this happened I was on the side of the highway and I began to unplug sensor to try and identify the problem. I got to the map sensor and it started right up. I hooked it back up after I got it running and drove away. Shortly after it stalled again and I went right to the map and unplugged it and it started right up. So I replaced the map sensor with another gtp one. The car was all good for about a week or so, and then started to stall out again! This time I depressed the schrader valve and had no pressure. So then I replaced the fuel pump with a new 01 gtp one. Hoping this was the problem I took it out and the f*ing thing stalled out on me again! This time I pop the hood when the car stalled and key on and saw fuel spraying out the schrader valve! I also replaced the fuel pump relay as a last effort still nada. I replaced the core with just a regular one out of a valve stem for now. Havent had the pleasure to drive it and find out if this was the problem yet. Everytime it stalls I am on the highway or cruising above 60 or so and the rpms drop to an idle and if I try to rev it up it will stall out. Last night after the fuel pump I almost got dead a few times because there was no shoulder to pull over to. So I had to get out push. I really need this fixed. Any advice would be greatly appreciated. Thanks guys.
