UPDATE:Alright so the car is still acting up. There is no check engine light on but when the car stalls out with a scanner hooked up to it, it trips a p0101 code. "Mass Air Flow (MAF) Circuit Range/Performance Problem" I did replace the maf again. There are no vacuum leaks that I can find. The map sensor has been replaced aswell. I have a fwi and a 3in. offroad d.p. also. I have a vacuum line coming from the lim to the map and to the new fpr aswell. Any ideas?
