Thread: What are the diffrences between an l67 and an l32 ?
Results 1 to 20 of 22
  1. #1 What are the diffrences between an l67 and an l32 ?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i know that my car is an l67 and correct me if im wrong but are the l32's the motors in the 04 and up? but what is the diffrence betweent the two motors ?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: What are the diffrences between an l67 and an l32 ?
    different rods, different blower.
    that's it.
    Not worth the added cost.
  3. #3 Re: What are the diffrences between an l67 and an l32 ?
    Ohio
    better castings...like oil passages.
  4. #4 Re: What are the diffrences between an l67 and an l32 ?
    Quote Originally Posted by 99PGPGT View Post
    Only in the front cover.
  5. #5 Re: What are the diffrences between an l67 and an l32 ?
    Ohio
    i know. should i pull up pics? lol
  6. #6 Re: What are the diffrences between an l67 and an l32 ?
    Sep 2011
    palm harbor florida
    i would actuaslly like to see that lol thats why my car blew up it was starved of oil because the oil passages fromthe oil filter neck were all clogged up and caused the #6 piston to spin a bearing
  7. #7 Re: What are the diffrences between an l67 and an l32 ?
    Quote Originally Posted by Doug 97 gtp View Post
    Change your oil more often.
    If you buy another engine, make sure it looks clean on the inside.
  8. #8 Re: What are the diffrences between an l67 and an l32 ?
    Sep 2011
    palm harbor florida
    i did -.-about every 2800 miles my car was old and abused. it had the original plugs and wires... my car was completly original wiht 162k on it lol
  9. #9 Re: What are the diffrences between an l67 and an l32 ?
    Ohio
    L67/L36
    L32/L26
  10. #10 Re: What are the diffrences between an l67 and an l32 ?
    Sep 2011
    palm harbor florida
    wait the l67 and the l32 are supercharged motors correct? because those pics dont look that diffrent.
  11. #11 Re: What are the diffrences between an l67 and an l32 ?
    Jul 2012
    Chicago
    Exactly..
    -Carl
  12. #12 Re: What are the diffrences between an l67 and an l32 ?
    Ohio
  13. #13 Re: What are the diffrences between an l67 and an l32 ?
    All SII+ timing covers will fit any of the blocks. Namely because the blocks are all the same.
    Those both are supercharged engines, but the difference in the timing covers is the larger opening.
  14. #14 Re: What are the diffrences between an l67 and an l32 ?
    Sep 2011
    palm harbor florida
    ohhhhhh. gotcha. has anyone tried to open up that hole for better flow ?
  15. #15 Re: What are the diffrences between an l67 and an l32 ?
    Ohio
    you can try, but when you blow your bottom end again, don't come crying to us.
  16. #16 Re: What are the diffrences between an l67 and an l32 ?
    Sep 2011
    palm harbor florida
    hey it wasnt my damn fault. who needs oil preasure hahahahah
  17. #17 Re: What are the diffrences between an l67 and an l32 ?
    Ohio
    Better yet, you need to understand that the timing cover is not the biggest reason for engine failures on a 3800... the oil gallery farthest from the pump is the problem.
  18. #18 Re: What are the diffrences between an l67 and an l32 ?
    Sep 2011
    palm harbor florida
    are you talking about the pick up tube ?
  19. #19 Re: What are the diffrences between an l67 and an l32 ?
    Ohio
    no. the gallery holes that lube the crank.
  20. #20 Re: What are the diffrences between an l67 and an l32 ?
    Sep 2011
    palm harbor florida
    ohhhhhhhhhhhhhh i just had a brain fart
  1. L32,L26,L67,L36 Diffrences?
    By TDCRacing in forum General Tech Discussion
    Last Post: 01-26-2009, 12:17 AM
