Thread: muliptle misfire code when boosting
Results 1 to 13 of 13
  1. #1 muliptle misfire code when boosting
    SE Level Member johannib's Avatar
    Jan 2013
    Traer, Iowa
    Ok, so I just bought an 02 GTP with 207,000 miles on it. Previous owner put on 50,000 of those and did no engine maintanence besides new plugs and wires and regular oil changes. Not sure how long ago though. When I test drove the car it had a full tank of gas and seemed to run perfect, bought the car and ran the rest of the gas out before refilling. Wife put 89 octane in it plus 1/2 can of seafoam, and drove it to work for a few days, she says SES light flashed at her while trying to pass and car bogged down. So in researching this site, I figure out the flashing SES light is going off because of misfiring at that moment.
    So I borrowed a friends scan tool and it had three stored codes, one for low coolant temp, one for multiple misfire and one for EGR (don't remember which one now). So I notice car never gets about 165 degress while driving, bad deal in cold winters in Iowa, takes for ever to heat up cabin in car. I suspected bad thromostat. Take old thermostat out and notice the previous owner/owners drilled a small hole in a 195 degree stat. Replaced with new 195 degree stat and new gasket. Solved problem, car runs around 195 degrees, does not overheat, and have great heat in the cabin! So first code fixed.
    Figured I start tackling the misfire code, so first thing I changed out was the fuel filter, its cheap and easy... Still misfires, and when I say misfires I mean at 55 to 60 Mph when it needs a little more throttle, and if push it down to WOT does it occasionally. So next up was visual inspection of wires and coil packs. Removed the aluminum heat shields from plug wires, maybe arching a spark, and also cleaned up all the coil pack to wire connectors with some fine sandpaper. One connector was rusty, cleaned up good and wire seems to fit ok. Cleaned MAF sensor with CCR MAF sensor cleaner. Not throwing any codes for MAF sensor but just some PM. Stock air cleaner, looks decent.
    Suspect bad gas or at least not high enough ocatane, ran gas out to about 1/4 tank and refilled with 91 octane. Car seems somewhat better but still get the flashing SES at the stated above conditions. Oh, I cleared the codes 5 days ago and have driven it daily since, and only code I'm getting now is the multiple misfire code, the other two did not come back. Also noticed the boost was only going 1/2 to 3/4 on boost guage and was erratic at WOT. Upon further inspection, noticed the boost bypass solenoid electrical connection was unplugged. Plugged back in, guage reads 100% boost at WOT now.
    Talk to previous owner last night, he never had an issue running 89 ocatane, didn't notice the boost problem (not mechanically inclined) and he didn't unhook the wire to Boost bypass solenoid. Said car has always ran fine with no problems. The car starts right up and idles and purrs like a kitten. It runs out smooth except when you want a little more boost, if you stay out of the boost it seems fine.
    So where should I start? I want to methodically troubleshoot this issue, to find the exact cause so don't want to shotgun parts at it. I do not smell rotten eggs from exhaust but not sure if the CAT should be my next replacement. I have no idea when it was changed last. This car has no MODs done and I'm not interested in changing the factory setup UNTIL it is running to factory specs.
    Ordering parts for LIM gasket update, exhaust elbows, new upper and lower injector orings, plugs and wires to do in a couple weeks. Should I also replace the injectors at this time with reman injectors?
    Sorry this is so long but the more info is always better when diagnosing. Look forward to your suggestions and ideas on how to proceed.
  2. #2 Re: muliptle misfire code when boosting
    Replace all the spark plugs with new Ac delco's and go from there. Its very possible the spark plugs that were put in it a long time ago are the wrong ones and have started failing. Try that first then we'll be able to try a few other possible causes.
  3. #3 Re: muliptle misfire code when boosting
    Jan 2013
    Traer, Iowa
    Ok, I'll swap them out tonight. Was going to replace when I had everything off to replace the LIM gaskets (easier to get to the back ones then) but what the heck I'm up for a small challenge. Will do just the plugs, cause like I said I'm curious to know exactly what it is. Then I'll test drive it and see how it acts. Will keep you posted.....
  4. #4 Re: muliptle misfire code when boosting
    St. Louis
    FYI, you MUST run at least 91 octane in that car (93 if you can get it). Do NOT run the 89 as it can act as you describe and can be very harmfull to the motor. The last thing you need is a chipped piston (new motor time). S/C cars have to have premium fuel. Do the plugs as FFDP said and then get some more 91 in there minimum.
  5. #5 Re: muliptle misfire code when boosting
    Jan 2013
    Traer, Iowa
    Ok, got new plugs installed, while installing plugs I ohmed out the wires also. They all looked good except when I got to #5 plug wire, was reading an open. Upon investigation I could get a reading while touching the wire going to the clip but not the clip it's self. So may have had an issue with it arching to the coil. Got a set of new plug wires and installed. The old plugs looked like they were running hot to me, very dark brown coloration but I've never inspected plugs from a SC car before so maybe thats normal. Almost like a rust color brown on elctrode and tips, not actually rusty tho...
    Test drove car and still doing the same thing, it ONLY does it when the car is adding boost, when I say adding boost I mean when I can see the boost indicator on dash start to light up. The car changes sounds and starts to run rough. If you keep it in the boost then the SES light starts to flash indicating a misfire. The car runs great until it tries to boost. I sprayed all vacumn lines with carb cleaner while idling to check for leaks and all looks good. If I floor the car the boost indicator will show 100% like it should.
    Thinking maybe I should get an HEI ignition tester and check each plug wire and coil pack to make sure it is getting proper spark under load.
    Thoughts?..........
  6. #6 Re: muliptle misfire code when boosting
    Have a borescope handy?
    Hearing that the previous owner ran 89 octane, I'm thinking it's time to ask him how many plugs were mangled when he replaced them. I'm thinking the low octane with boost may have chipped some pistons. However before we condemn the pistons and scare you to hell, let's talk further.
    Do the coils on the car look original or are they red MSD coils? MSD coils are known to cause issues at higher rpm, stock are better.
    What kind of plugs did you use? Platinum are never suggested in our cars, iridium or copper are the way to go.
    Do you have a scanner capable of telling you which cylinders are misfiring when you drive it? If it was a shared coil (3/6, 1/4, 2/5) then you could replace just that coil.
    That's where i'd start.
  7. #7 Re: muliptle misfire code when boosting
    Jan 2013
    Traer, Iowa
    No borescope, would have to rent or borrow one.
    Coil packs are original, still have the cylinder #'s written on them. I put in AC/Delco iridium plugs, same as the ones I removed. I do not have a scanner that can tell me which cylinder.
    I used a MAC scanner from a friend (no recent software updates) and also had Advance Auto run a scan. They both only gave me the 3000 code for muliple random misfire. I'm hopin for the best but expecting the worst.
    The other thing I'm bothered with is why on earth he ran the car with the BBV electrical connector unhooked and never noticed anything? The plugs I removed showed no signs of physical damage form debris but then they probably wouldn't.
    If it is a coil pack will it show up when I test it with an HEI tester. Have one ordered and will be a few days before it gets here. No auto parts stores carries one around here, ughh!
  8. #8 Re: muliptle misfire code when boosting
    clogged cat can also cause multiple misfires. and make the sel light flash when in the gas. with over 200,000 miles thats a real possibility.
  9. #9 Re: muliptle misfire code when boosting
    Jan 2013
    Traer, Iowa
    Has anyone checked for a partailly plugged CAT by checking vacuum? I was going to try this tonight by T ing in on the brake booster vacuum line.
    This is what I read....
    If the your converter is plugged, it will create a restriction in your exhaust system. The buildup of backpressure will cause a drastic drop in engine performance and fuel economy, and may even cause the engine to stall after it starts if the blockage is severe.
    The easiest test for converter plugging is done with a vacuum gauge. Connect the gauge to a source of intake vacuum on the intake manifold, carburetor or throttle body. Note the reading at idle, then raise and hold engine speed at 2,500. The needle will drop when you first open the throttle, but should then rise and stabilize. If the vacuum reading starts to drop, pressure may be backing up in the exhaust system.
  10. #10 Re: muliptle misfire code when boosting
    You sure could test it that way. Although I'd T in by the fuel pressure regulator or boost soleniod. Nice easy area to get to and most gauges have smaller fittings.
    I don't know about the HEI deal. Never even heard of one before.
  11. #11 Re: muliptle misfire code when boosting
    Jan 2013
    Traer, Iowa
    Well I called the local salvage yard on my way home from work and they had a coil pack for $30. They let me use it to see if it would solve my problem. Got there and it was all 3 coil packs and the ICM for $30! Replaced coil 1/4 no change, replaced coil 2/5 no change, replaced coil 6/3 and PROBLEM SOLVED! Car runs great now and has all kinds of get up and go! Guess I will go pay my $30 tomorrow and keep the other 2 coil packs and ICM for spares! Thanks guys for your help.
    Bill google HEI ignition tester and see what I'm talking about. Now I'm curious to see if this would have found the bad coil pack. It puts a heavy load on the wire and coil to simulate high load situations, which when I was boosting it would have been a higher load on the spark plug. Going to purchase one anyway to have in my aresenal of tools for troubleshooting!
  12. #12 Re: muliptle misfire code when boosting
    St. Louis
    Good price on the 3 coils and ICM. I just paid $40 for mine when my Bonne ate the ICM. Def. keep a spare ICM around as my GP ate one last year as well. Just shut off while I was driving then would barely run.
  13. #13 Re: muliptle misfire code when boosting
    Nice price for sure.
    I go old school to test packs. I hook up the HPT, take it for a spin and see the cylinders that are complaining. Then I dive bomb it and go in for the kill.
  1. P0300 Code. Random Misfire NEED HELP!
    By JcGTP39 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2011, 10:12 PM
  2. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
  3. Code p0304 misfire 4
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 02:21 PM
  4. Can a bad O2 sensor cause a misfire code?
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 08:01 AM
  5. cylinder misfire code on #4
    By valrathe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2010, 12:14 PM
