No borescope, would have to rent or borrow one.
Coil packs are original, still have the cylinder #'s written on them. I put in AC/Delco iridium plugs, same as the ones I removed. I do not have a scanner that can tell me which cylinder.
I used a MAC scanner from a friend (no recent software updates) and also had Advance Auto run a scan. They both only gave me the 3000 code for muliple random misfire. I'm hopin for the best but expecting the worst.
The other thing I'm bothered with is why on earth he ran the car with the BBV electrical connector unhooked and never noticed anything? The plugs I removed showed no signs of physical damage form debris but then they probably wouldn't.
If it is a coil pack will it show up when I test it with an HEI tester. Have one ordered and will be a few days before it gets here. No auto parts stores carries one around here, ughh!
