Thread: P0171 code after intake gasket change.
Results 1 to 14 of 14
  1. #1 P0171 code after intake gasket change.
    Jan 2013
    Texas
    this is what happened...
    while changing intake gasket, the rubber T that connects the vacuum lines broke and so i rigged a new one <- might be the cause
    when pulling out fuel rail and injectors, some wierd plastic piece on bottom after the o-ring broke. no leak cold be found.
    right after the intake gasket change, ran car for a good 40mins with no engine light. this mornin it comes on. also got a clicking sound coming from alternator. think i need a new one?
    please help me with this retarded P0171 code
  2. #2 Re: P0171 code after intake gasket change.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    injector tabs breaking dont matter. But yeah you have a vac leak somewhere.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: P0171 code after intake gasket change.
    Jan 2013
    Texas
    alrigth so replace all vac lines and T connector?
  4. #4 Re: P0171 code after intake gasket change.
    i replaced these vac lines and both T's.
    and the line on top of the TB was cracked as well. so i used a fat vac line to a smaller line that would fit inside the fat line, then to the plastic stock line, this line runs to the evap off the back of the sc.
  5. #5 Re: P0171 code after intake gasket change.
    Jan 2013
    Texas
    holy crap! just found the solution by looking at your pic. im missing THAT hose
    can u tell me where that hose goes? perferably a from - and - to pic
  6. #6 Re: P0171 code after intake gasket change.
    that vac lines goes inside the cars cab to the dash. it controls the fan directions. huge vac leak lol.
    look behind the engine for it, thats where i tossed mine when doing the lim gaskets.
  7. #7 Re: P0171 code after intake gasket change.
    Jan 2013
    Texas
    yeah lol. i that there was suppose to be something there.
  8. #8 Re: P0171 code after intake gasket change.
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    and your car ran smoothly with that off?
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  9. #9 Re: P0171 code after intake gasket change.
    Jan 2013
    Texas
    it did! for 40 mins straight. but the idle seems lower. idles at 900 instead of 1200. also if i rev it to 2000 or 2500 and release peddle, tach goes to 1500 and idles for 3 secs and slowly goes to 900
  10. #10 Re: P0171 code after intake gasket change.
    that vac line will come from the pass of the car. off the firewall.
  11. #11 Re: P0171 code after intake gasket change.
    Sep 2012
    bridgeport,NY
    Quote Originally Posted by 01gpgt01 View Post
    so if they are not there anymore its fine?
  12. #12 Re: P0171 code after intake gasket change.
    found a over view of that vac line.
  13. #13 Re: P0171 code after intake gasket change.
    Jan 2013
    Texas
    sweet thank you scotty
  14. #14 Re: P0171 code after intake gasket change.
    Hagerstown,Md
    Quote Originally Posted by Erik Adam Rodriguez View Post
    Thats correct
  1. Hi I'm new and have a p0171 code, can you help?
    By falconjohnd in forum Engine
    Last Post: 12-15-2011, 07:45 AM
  2. intake gasket change
    By NICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2011, 04:31 PM
  3. Intermittent P0171 code
    By mwzeigler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-25-2011, 06:10 AM
  4. intake gasket change guide
    By 94grandprix in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-08-2011, 07:38 AM
  5. s/c gasket leaking setting p0171
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 04:56 PM
