Thread: Max Boost With GEN 3 or GEN V
Results 1 to 20 of 28
  1. #1 Max Boost With GEN 3 or GEN V
    GT Level Member lilrocket's Avatar
    landis,nc
    So what is the most boost you have seen you GEN 3 or GEN V make just show boot number with pulley combo currently with my 1.8 Rockers, spring, s2 ic, headers, etc. with my 2.8 im @ 13-14
    98 DAYTONA 1110/1500: work in progress
    00 DAYTONA 216/2000: totaled but not forgotten parts car
    "Speed its my drug, the faster i go, the faster i want to go!"
  2. #2 Re: Max Boost With GEN 3 or GEN V
    I've seen 15psi. Not giving you more info as it doesn't apply to your rocker setup.
    Something to consider is that most of the gaskets in the motor were originally designed around a top number of about 13psi. Which the engine was engineered to never really hit 13psi. IIRC most say the limitation of stock head gaskets is in that 15psi area.
  3. #3 Re: Max Boost With GEN 3 or GEN V
    May 2008
    Schuyler, NE
    XP cam, LS6 springs, headers, 2.7 pulley. ~15psi....1500' elevation. Estimated DA: 4500'
  4. #4 Re: Max Boost With GEN 3 or GEN V
    i'd assume with head studs you could safely get away with a lot more.
  5. #5 Re: Max Boost With GEN 3 or GEN V
    Might come down to gasket before studs though.
    Not sure. I had one of everything and never had a problem
  6. #6 Re: Max Boost With GEN 3 or GEN V
    landis,nc
    i run a lot of nitrous throught the car right now im just tryin to up the boost to see how it all reacts im running aftermarket gaskets theyre intense mls i beleave i went just little more thickness to lower compression since i intended on sprayin the car a lot
  7. #7 Re: Max Boost With GEN 3 or GEN V
    Well hell then son...you gotta tell us stuff.
    I had
    SLP headers
    3" exhaust after that
    N* TB
    Gen V
    2.9"
    1.8 Rockers
    S1X cam
    S3 heads
    Ti retainers
    130# springers
    245mm converter
    3.29's
    Solid front mount (bonne)
    EWP
    Ported LIM to match heads and IC, and u bend cleaned up etc
    Full size WBS IC that hung into LIM about 3/4"
    Meziere 20gpm IC pump
    Extra res tank
    PS pump spacer from 00 Bville
    Oversized Deville Rad
    4" FWI
    00 style alt
    Thing reved super fast and left most wondering what happened.
  8. #8 Re: Max Boost With GEN 3 or GEN V
    May 2008
    Schuyler, NE
    I'm running 13 psi on a 3.0 pulley on a 125 wet shot with stock headgaskets and stock bolts.
    Keep it from detonating, and you won't have a problem. Detonation is the main reason headgaskets fail.
  9. #9 Re: Max Boost With GEN 3 or GEN V
    landis,nc
    Im sorry heres the list as of now
    SLP headers
    3" exhaust, no cat turbin mufflers straight through
    Ported L67 TB/ working om my Ls1 setup not finshed yet
    Gen V ported
    2.8 mps
    1.8 Rockers
    Ti retainers
    130# springs
    poly engine mounts all around
    Full size ZZP stage 2 IC Meziere 20gpm IC pump
    4" FWI
    msd coils and wires
    160 tsat
    42.5 lb injectors
    255 pump
    pump rewire
    ic controller
    nos wet kit 150 as it sits
    mls gaskets
    zzp pcm
    dont think i missed anything
  10. #10 Re: Max Boost With GEN 3 or GEN V
    One thing to caution you on. If you see higher rpm issues, mainly misfires. Swap the MSD's for stockers. MSD's seem to have high rpm issues anywhere from a month to a year from being new.
  11. #11 Re: Max Boost With GEN 3 or GEN V
    landis,nc
    ill def keep that in mind my problem is i hate the rpm dip when it shift from 2-3 and 3-4 most of the stuff i do is from a roll anyway its just a second gear pull seems to lag once it shift wearther im spraying it or not but its nasty up until that point
    thanks for the cation on the coils ive been doin a little research on them also is there any tip on a certain wire to us do the bigger 10mm wires actualy work in our platforums
  12. #12 Re: Max Boost With GEN 3 or GEN V
    landis,nc
    what are the big gains in the xp cam over the 1.8 rockers just wondering because i had the xp cam in the car and really didnt notice a whole lot of differance in the mid range from were i run the car from ... debatin on throwing it back in just tryin new setup to see how the car reacts to certain setups
  13. #13 Re: Max Boost With GEN 3 or GEN V
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    16.5psi
    SIX, E85, TOG's, GenV w/2.8 pulley, Ti Retainter, Crow #105, #60 injectors, Walbro 255, TEP Trans with 300m & 2.93 7/8"....stock head studs and head gaskets
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  14. #14 Re: Max Boost With GEN 3 or GEN V
    Apr 2011
    Columbus, OH
    Quote Originally Posted by lilrocket View Post
    Sell the rockers and put the XP cam back in there. More total power under the curve and is a very streetable cam. Just my opinion....
  15. #15 Re: Max Boost With GEN 3 or GEN V
    landis,nc
    i still have the cam never sold it just tryin to see whats the best setup and power band thanks i like the dyno numbers not too shabby
  16. #16 Re: Max Boost With GEN 3 or GEN V
    Clearance the heads and run the 1.8's on the XP?
    I had...
    BRE 100% Balanced Rotating Assembly (L32 rods/L67 pistons), BRE Custom Ported Heads (L32's), Thrasher cam, 130's w/Ti R's, TEP trans with 3.29's, 42.5'ers, 9" Open Cone on a Ported GenIII M90/LIM w/ LS1 TB setup...had a 3.0" on there for most of the time...Custom Pacesetters (catless then 3" all the way back), tuned via HPT on pump gas, no methanol, no IC...never saw more than 10-11~ at the shift.
  17. #17 Re: Max Boost With GEN 3 or GEN V
    May 2008
    Schuyler, NE
    Having a stock cam is really holding you back.
  18. #18 Re: Max Boost With GEN 3 or GEN V
    landis,nc
    what would i have to clearance to run the 1.8 with the xp cam? this would def. be something i would be interested in doing
  19. #19 Re: Max Boost With GEN 3 or GEN V
    Pull heads.
    Take to machine shop.
    Have machine shop install new guides and have them milled .100" to allow for the lift...I think when you mill off .100", max lift is good for around .600"~...Can't remember what the XP + 1.8's made. It's somewhere close to that...
  20. #20 Re: Max Boost With GEN 3 or GEN V
    May 2008
    Schuyler, NE
    You would have to clearance the valve guides for about .650" lift. But, you won't gain any power by doing it. Just run an XP with stock rockers.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
