Thread: I need some help with mods
Results 1 to 20 of 23
  1. #1 Re: I need some help with mods
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    heres the order I went. All these mods were installed withing 2 weeks of each other:
    thermo, downpipe, wizair, pcm, plugs
    going to plog then 3.6 pulley next. I'm guessing this is going to put me at a 13.9-14.1.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: I need some help with mods
    GT Level Member GTPRiley's Avatar
    Oct 2008
    Abilene Texas
    04compG what are you running right now?
    Riley Greear
    "Bastardized" 2004 Grand Prix GTP Comp G. 180* Tstat, Fender Well Intake, AL 104's SSAC Headers 3.5 MPS XP-HOT Cam and 105# springs.
  3. #3 Re: I need some help with mods
    Feb 2008
    South Bend, IN
    Not sure. I'm ordering the plog and 3.6 pulley right when I get back from Pennsylvania at the end of next week. Someone on the other boards had an 04 compg with my current mods (i think he had AL104 plugs though) plus the plog and 3.6. The car ran a best of 13.9 just a few days ago. It also had a run of 14.
    i'm going to try to make it to the local strip once I get the pulley and plog on. I want my car to run consistant high 13's also so I might have to think of another mod or two to do after the pulley and plog, depending on what my times are. I think its a good idea to get rockers and springs if you are going to drop to a 3.5" pulley on the GenV and that costs a lot of $$$ so I want to avoid that and still get consistent high 13's using only new and what I think are the best parts ( which of course always cost the most money).
  4. #4 Re: I need some help with mods
    Banned
    oswego
    I agree with said suggestion
    Intake, headers, tstat, plugs, ect.
    Don't waste your time with plogs and dp's. Headers are one of the biggest mods for gp's period. Yeah pacesetters suck to put on (i didn't have a problem...) but if you order them from zzp they take care of all the problem area's and you can get the cheap non-coated ones and use header wrap to conceal the uglyness.
    but, but, but..... won't they crack? awwww horse ****. I've had mine wrapped since i got them and i know i get higher egt's than anyone else around when i'm running my 100shot and they haven't cracked. The ceramic coating blows balls and looks like **** in a year or so anyways. Again if you can't spend the money on headers just save up until you can afford them, don't waste your money on a plog and dp unless you're happy running high 13's low 14's I know i'm sure the hell not. Just my .02 take it as it is.
  5. #5 Re: I need some help with mods
    Feb 2008
    South Bend, IN
    Yea, if you are content with the Pacesetters get those instead of the Plog/dp combo. The pacesetters are made out of mild steel though and theres a reason they are substantially cheaper than the competition. I would have wanted the ZZP or SLP headers and your looking at $1,000 + install.
  6. #6 Re: I need some help with mods
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Just get some SS Autochrome ones, they're stainless steel SLP knockoffs and are only like $360 shipped.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  1. mods for the gxp
    By miller in forum 5.3L V8 (LS4)
    Last Post: 01-13-2010, 01:34 AM
  2. Three GPs with T/A mods
    By Injun #4 in forum Visual/Body Modifications
    Last Post: 06-16-2008, 08:41 PM
  3. Mods to Help MPG
    By anks106 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2008, 08:14 PM
  4. Gt mods?
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-07-2008, 07:16 AM
  5. best first mods to do
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2007, 07:50 AM
