Thread: Vacuum line hack job, explain to me why or if they were on to something
Results 1 to 20 of 25
  1. #1 Vacuum line hack job, explain to me why or if they were on to something
    Dec 2012
    Minnesnowta!
    I just picked up a 1997 gtp with 1/4 million miles for cheap. It needed a s/c coupler, but upon further investigation it needed alot more. It needed the LIM changed and upon taking the snout of the s/c there was no oil in it and the bearings were toast...that was the easy part. Now looking at it and looking at a diagram, there are alot of vacuum related parts that were deleted, I'm posting two pictures, one of what I have and another of what i can assume it should look like....Were they on to something with deleting so much or on something...
  2. #2 Re: Vacuum line hack job, explain to me why or if they were on to something
    Yoga city
    prolly they were going off a 98+ diagram, the 97 had a different vacum setup, i believe it was an extra tree
  3. #3 Re: Vacuum line hack job, explain to me why or if they were on to something
    Dec 2012
    Minnesnowta!
    They added/deleted more than just a tree...the whole evap system is gone...and why a vacuum line to the washer tank?
  4. #4 Re: Vacuum line hack job, explain to me why or if they were on to something
    Well ...first off no vacuum goes to the washer tank. Close though. The washer tank has it's own line and the line you think goes to it, actually heads to the vacuum can that is buried in the drivers front fender.
    It looks like the evap was removed from your diagram. As well your boost control is missing and therefore running off vacuum which it can do w/o problems. Look at your vin. What is is the 8th digit?
  5. #5 Re: Vacuum line hack job, explain to me why or if they were on to something
    Does the supercharger have the tree on it by the boost actuator? Likely it doesn't. Only 96/97 production motors (GP only saw the motor in 97) had the tree by the actuator. They they changed it up for some reason and ran things in a less complicated way.
  6. #6 Re: Vacuum line hack job, explain to me why or if they were on to something
    Yoga city
    lol what? i see that now lol hillbilliy ingunity. well they delted the evap as some ppl do but why run anything to the washer line? Do your hvac settings work? like will it change from bi level defrost?
  7. #7 Re: Vacuum line hack job, explain to me why or if they were on to something
    Joo gotta read wut I rote Jayyyyyke
  8. #8 Re: Vacuum line hack job, explain to me why or if they were on to something
    Yoga city
    bill you do realize i had to replace all my vacum lines in my 97 to get my HVAC to work right? ive been through a 97 vacum system before. maybe i didnt retain all the info but im just a shadtree mechanic, leave me alone lol
  9. #9 Re: Vacuum line hack job, explain to me why or if they were on to something
    Dec 2012
    Minnesnowta!
    I'm not just seeing things, they had a vacuum line from the TOP of the washer tank running to the top of the s/c...on that 3 way vacuum port....Crazy ....shouldn't that run into the firewall(?) instead?....8th is "1"...I guess if it can run without the evap system..that's great but the s/c boost control..that's my concern
  10. #10 Re: Vacuum line hack job, explain to me why or if they were on to something
    Yoga city
    how that motor no boom?
  11. #11 Re: Vacuum line hack job, explain to me why or if they were on to something
    Dec 2012
    Minnesnowta!
    I don't know..I didn't mess with the car enough before I tore it down to see how the hvac system worked..
  12. #12 Re: Vacuum line hack job, explain to me why or if they were on to something
    Ok,
    1. They eliminated the boost control from the sound of things and it's running off vacuum. This is ok, or you can hook a soleniod back up.
    2. I was asking fo the vin, to determine if it was a top swapped or a real GTP. It is a real GTP
    3. Triple check that washer line. The route of the vacuum line to the can is right along with the washer line and unless they were trying to drown the motor with methanol (most washer fluids) then it can't go to the charger. A test is to try the washers on the car. If they work, it's going to the canister and not the washer tank.
  13. #13 Re: Vacuum line hack job, explain to me why or if they were on to something
    Dec 2012
    Minnesnowta!
    Ok, Theres a line from the top of the s/c going to the boost control, and on the other end where it is supposed to go to the solenoid it isn't capped off...should it be? There is a washer line running to the wipers from the pump..I've never seen a vaucuum line run like this...Where should it go otherwise? somewhere with the hvac? or capped it not needed?
  14. #14 Re: Vacuum line hack job, explain to me why or if they were on to something
    Dec 2012
    Minnesnowta!
    Also there is no codes thrown. seemed to had run fine except for a noisy s/c...boost gauge seemed to work on the dash..Only got it to go about half, but didnt really get on it either..
  15. #15 Re: Vacuum line hack job, explain to me why or if they were on to something
    No arguement from me that it's goofy. It runs along the front bumper and over to the vacuum ball.
    Somewhere the vacuum is either t'd and goes into the cabin or it comes off the ball and into the cabin on the driverside. I didn't trace it all, but enough to see it's goofball.
  16. #16 Re: Vacuum line hack job, explain to me why or if they were on to something
    Dec 2012
    Minnesnowta!
    Well, i'm stumped...I didnt even have a vacuum ball in the fender...wtf.....Well if the boost contol can run off vacuum..great we'll leave it be...until I get the car running and see what's really going on, this was a huge help!
  17. #17 Re: Vacuum line hack job, explain to me why or if they were on to something
    Some may not have the vacuum ball. But then that really confuses me as to where they routed the line and why they went around the car w/o heading to the ball or going into the cabin.
  18. #18 Re: Vacuum line hack job, explain to me why or if they were on to something
    Dec 2012
    Minnesnowta!
    All in All that one really doesnt concern me yet...It was the evap deletion and the boost controler that i was worried about
  19. #19 Re: Vacuum line hack job, explain to me why or if they were on to something
    Seems like they also programmed the pcm to not report the errors on either.
  20. #20 Re: Vacuum line hack job, explain to me why or if they were on to something
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    if that ball isnt in the fender then does the line still run through the bumper
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  1. Vacuum Line
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 03:05 PM
  2. i need a vacuum line
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 04-20-2010, 09:07 PM
  3. Where is the vacuum line??
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2009, 01:04 AM
  4. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
  5. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
