Thread: bad MAF sensor?
Results 1 to 3 of 3
  1. #1 bad MAF sensor?
    Aug 2012
    Pittsburgh
    Hey everyone,
    First post, been reading through the forum a ton the past few years, helped me solve a lot of problems.
    I've currently got a '98 Daytona Pace Car edition GTP, and it's got a problem that is just killing me. I am getting about a 2k RPMs idle, and about 11mpg local, 14mpg absolutely grannying highway. I'm getting sluggish gas response, and my super charger only will ever hit half boost, even completely open throttle. I should also note if I open the throttle, I get literally about a mile per gallon. Under the hood, I found my MAF fuse is blown. Any time I try to replace it, it blows instantly at start, but ONE time I got it to start without blowing the fuse and it ran like absolute garbage. Fluctuating RPMs, about 300-1000, constantly trying to stall unless I gave it gas. Revved it up to about 3k RPMs and the fuse blew and it went back to ~2k RPMs.
    To preface this a little, the problem started when I noticed I was getting sluggish gas response, and RPM fluctuation. I ripped apart the throttle body and cleaned it out. It was carbon coated beyond belief. After that is when the problem became so noticeable I don't have a code reader and have been working 60 hour weeks so time has been hard to come by to try to get a code reader or anything like that.
    Does a bad MAF sensor seem like a likely culprit? Just don't want to get a new one and find myself it wasn't the problem to begin with.
  2. #2 Re: bad MAF sensor?
    If you unplug the maf sensor and rev's drop back to normal, you found the issue. Its either the sensor or the wires going to it.
  3. #3 Re: bad MAF sensor?
    Aug 2012
    Pittsburgh
    That's the thing, unplugging the sensor doesn't make a difference with the fuse out of the circuit the sensor is basically unplugged. Like I said, the one time I got it to run with the fuse intact is when it ran so terribly.
  1. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
