Thread: SD Headers fan clearance
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: SD Headers fan clearance
    Flip your upper motor mounts and make sure your lower mounts are up to par and it shouldn't have a issue.
    04 Comp G.
  2. #22 Re: SD Headers fan clearance
    on my 03 gmc, when my clutch fan went bad for the 3 rd time, and i was out of warranty, i took the stock fan off and got this pair of 16' pro comps fans for less then 50 for the pair. spent another $8 on a mounting kit.
    a GP would need a smaller fans of course, but these fans really do work well. my truck ran a line cooler as well. and the a/c was never colder either.
    and this was how i ran them, no more fan shroud. and it ran cooler. when parked if you dropped a sheet of paper at the grill it would suck the paper right to the grill. make sure they have S blades as well.
  3. #23 Re: SD Headers fan clearance
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    You keep saying this but it's not the case. I had new mounts all around. I flipped my dog bones. It didn't help the headers were resting against the metal motor fan casing.
    Since noone else has had the issues I assume I have a bad batch of sd headers. This was the cheapest most time efficient way of fixing it since I wasn't about to rip off the headers and pay more then the fans to send them back for replacements
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #24 Re: SD Headers fan clearance
    Keyword "shouldn't" there's always gonna be that one guy that it doesn't work for while it has worked for 100 other people's I throw the suggestion out there because the odds are great that he won't need slim fans. But now in case he does have the issue he knows the next step to take.
    04 Comp G.
  5. #25 Re: SD Headers fan clearance
    SE Level Member darionmilton's Avatar
    Jun 2010
    Lansing, Michigan, United States
    Shoulda got ssac lol
  6. #26 Re: SD Headers fan clearance
    Ohio
    Quote Originally Posted by darionmilton View Post
    Why?
  7. #27 Re: SD Headers fan clearance
    Jun 2010
    Better clearance. And when they get hot they change colors
  8. #28 Re: SD Headers fan clearance
    They are the same design.
  9. #29 Re: SD Headers fan clearance
    Ohio
    Oh yeah?? I didn't even know that!!
    Wow, so I guess my SD headers didn't do the exact same thing.
    But hey, sd headers are ****ty and you should just get ssac.
  10. #30 Re: SD Headers fan clearance
    Ohio
    Oh and btw, it's stainless steel genius.. It changes color when it goes through enough heat cycles.
  11. #31 Re: SD Headers fan clearance
    Jun 2010
    Quote Originally Posted by 99PGPGT View Post
    Im having a hard time telling if that's sarcasm....
  12. #32 Re: SD Headers fan clearance
    Wrong. Same design. Both are going to turn rainbowish when they've been heated enough.
    04 Comp G.
  13. #33 Re: SD Headers fan clearance
    im pretty sure it was lol
  14. #34 Re: SD Headers fan clearance
    Ohio
    you'd be surprised scotty
  15. #35 Re: SD Headers fan clearance
    And you must not known of all the guys recently that have ordered SSAC and have not been shipped and took weeks to get refunds back from some but we still recommend them? < sarcasm.
    SD are winning right now
    04 Comp G.
  16. #36 Re: SD Headers fan clearance
    Feb 2013
    Detroit, MI
    Haha I will flip them but thanks. Well just wait n see. Appreciate it everyone.
  17. #37 Re: SD Headers fan clearance
    Jun 2010
    Lol sorry. . Major brain fart.. my apologies.. better?
  18. #38 Re: SD Headers fan clearance
    Oct 2011
    MI
    Yeah ive had both brands. No issues with previous set of ssac. Unfortantely I couldn't get a hold of them.. Heard some bad rumors. So I just called sd and they were at my door in a couple days.
  19. #39 Re: SD Headers fan clearance
    Oct 2011
    MI
    Here's a shot of my buddies with slp headers it must have something to do with the 04+ cars for clearance
  20. #40 Re: SD Headers fan clearance
    Ohio
    04+ cars and impalas usually have low clearance. Both my friends 04 and impala are damn near touching the heat shield.
  1. hood clearance
    By Lacboi in forum Visual/Body Modifications
    Last Post: 02-24-2012, 09:13 AM
  2. I/C hood clearance
    By 99prixgt in forum General Tech Discussion
    Last Post: 11-27-2010, 12:02 AM
  3. 18s. no clearance and tire rub???
    By joshsGT in forum Tires & Wheels
    Last Post: 12-13-2009, 08:56 PM
  4. Would these have clearance?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 12-27-2008, 01:29 PM
  5. oil filter s-belt clearance
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 11:55 AM
