Thread: Desperately need help!
Results 1 to 17 of 17
  1. #1 Desperately need help!
    Nov 2010
    Iowa
    Okay my '99 gtp is having some issues. The MAF, ICM, TPS, fuel filter, and fuel pump have all been replaced recently. Now my problem is that my car will die while driving. Sometimes it dies without warning. Sometimes the car will make a thud noise similar to a hard shift and it will also die unless i immediately let off the throttle. The car idles fine. I have no idea. Ive checked everything it seems like. I just cant continue to keep throwing money at it. I need to pinpoint this problem. Any ideas?
  2. #2 Re: Desperately need help!
    Crank sensor maybe.
  3. #3 Re: Desperately need help!
    St. Louis
    Happen to notice if your tach drops to 0 yet the car is still running? Will it fire right back up? Even if not, I 2nd the crankshaft position sensor theory.
  4. #4 Re: Desperately need help!
    Nov 2010
    Iowa
    well the tach drops to zero because the car dies but sometimes if i quickly try to start it again and turn the key just to the ON position the tach goes to about 800 rpm but it has no power. When the car goes to die, if it doesnt die right away, the tach drops and sits at around 800 rpm and the car wont accelerate so I have to shut it off and restart. Most of the time it just dies randomly and quickly. It will usually fire right back up, but if not it will restart the 2nd or 3rd try.
  5. #5 Re: Desperately need help!
    Wichita
    Does your car idle high? What are your RPMs at idle? @ 60? My guess is a massive vacuum leak.
  6. #6 Re: Desperately need help!
    Nov 2010
    Iowa
    Also, if im just cruising, when i let of the throttle the tach jumps up about 200 rpm before dropping as it should. I dont know if thats related buts thats something ive noticed for awhile
  7. #7 Re: Desperately need help!
    Quote Originally Posted by SCbuick010 View Post
    thats normal, the same thing happens if you tap the brakes in 4 th gear, with out letting off the gas at cruising speed. it the torque converter just unlocking.
  8. #8 Re: Desperately need help!
    Nov 2010
    Iowa
    it idles at 700-800ish at idle and going 60mph its at 2000 at least.
  9. #9 Re: Desperately need help!
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    CPS
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  10. #10 Re: Desperately need help!
    Dec 2012
    Des Moines, IA
    I believe its the Crank Sensor if you have already replaced the MAF.
    ...A gear-head in my own way...
  11. #11 Re: Desperately need help!
    Nov 2010
    Iowa
    Are you guys pretty sure its the crank sensor then? If so Im taking my car to the shop and getting it replaced with my tax returns. How much am I looking at?
  12. #12 Re: Desperately need help!
    It's pretty easy to do yourself at a shop probably $200-$300
  13. #13 Re: Desperately need help!
    Take a look at the "how to replace a crank sensor" write up. Part should be $20-$30 and it's under an hour for a guy using only hand tools.
  14. #14 Re: Desperately need help!
    Nov 2010
    Iowa
    Well normally I would tackle this project myself because I do almost all the work on my own car, but I live in an apartment without a garage and I usually do the work at my buddy'a house but it's just too damn cold for me to be working on a car outside. I replaced my fuel pump last year in the dead if winter in 5* weather..yeah that wasn't a great experience lol
  15. #15 Re: Desperately need help!
    Dec 2012
    Des Moines, IA
    Yes, it is too cold here. I hate it! I hope Spring comes soon.
  16. #16 Re: Desperately need help!
    Jan 1970
    Maquoketa, Iowa
    Could be fuel pump wiring as well, after it dies, open the test port/schrader valve and see if you have pressure still, do it carefully if it's hot or with a large towel. Did you replace the pump itself or canister and everything?
  17. #17 Re: Desperately need help!
    Nov 2010
    Iowa
    I replaced the whole unit...everything. The car gets good fuel pressure according to the shop that put the ICM in. The day after I got the car back from getting the ICM replaced I went out and tried to have some fun but the car wouldn't go too high in rpms and then died. Now it dies at random. I don't/can't drive it spiritedly anymore(not that i beat on it, but every now and again I like to have some fun) I'm annoyed
  1. Headlight Issue...desperately need help!
    By Pontiac735 in forum General Tech Discussion
    Last Post: 11-26-2010, 09:14 PM
