Thread: SD Headers fan clearance
Results 1 to 20 of 40
  1. #1
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I have all new mounts. Flipping the dog bones is not going to push my motor towards the firewall am I right? If that's the case I'll go do it now..
    The middle outlet off the front header is touching the passenger METAL Fan casing. Theres nothing to shave. The front header attaches to the motor. Nothing to move. My crossover doesn't leak so I'd have to assume I've got it in to my satisfaction. (that's what she said) Iol
    I'm guessing I got a bad batch of headers because I had to grind the front header for it to fit inside crossover.. Horrible flange job. I didn't even get clamps from them.
    Now I'm sure you solved your problem that way but mine was best solved with new fans.. besides that will give me plenty of room later depending on the route I go with the vehicle.
    I'll have before and after shots if anyone is interested in seeing them in a few days.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: SD Headers fan clearance
    Quote Originally Posted by rperry435 View Post
    flipping the dog bone mounts will hold the engine tight right where you looking at it sitting in park. if you look into the mount from the side, it tells the whole story.
    in park, im sure if you grab the sc snout, and push and pull the engine, it will move some. flip the mounts, and all that moment is now gone.
  1. hood clearance
    By Lacboi in forum Visual/Body Modifications
    Last Post: 02-24-2012, 09:13 AM
  2. I/C hood clearance
    By 99prixgt in forum General Tech Discussion
    Last Post: 11-27-2010, 12:02 AM
  3. 18s. no clearance and tire rub???
    By joshsGT in forum Tires & Wheels
    Last Post: 12-13-2009, 08:56 PM
  4. Would these have clearance?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 12-27-2008, 01:29 PM
  5. oil filter s-belt clearance
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 11:55 AM
