Thread: Hole In Header :-(
Results 1 to 20 of 32
  1. #1
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Quote Originally Posted by blueguy91 View Post
    ^^That.
    I bet neither of you have either flipped the dog bones, replaced them with polys, OR checked the condition of the lower motor/trans mounts.
    If you have, then I suggest trying to shove that header in the crossover better, because the only issue I've ever had with any set was when I had to give some Imp SS AC lines some love to clearance the front header, fans were not in the way whatsoever.
    My mounts are new just had the motor out.. Thanks though. And it's not a crossover issue the middle outlet off the engine is too long before it curves. I have an 04. Not sure what year yours is.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Hole In Header :-(
    Quote Originally Posted by rperry435 View Post
    The engine is too long, wat?
    lol.
  1. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  2. hole in VC
    By gtpinsc in forum General Tech Discussion
    Last Post: 01-23-2011, 10:50 AM
  3. so some a$$ hole wants to fight me...
    By mezzoni in forum The Rant Forum
    Last Post: 07-19-2010, 01:27 PM
  4. Could this be a hole in #1 piston?
    By guys00gtp in forum Off Topic Discussion
    Last Post: 06-24-2010, 03:27 PM
