Thread: Hole In Header :-(
Results 1 to 20 of 32
  1. #1 Hole In Header :-(
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Some how i found a hole in my front header. Would this cause an exhaust leak tick that gets louder as i accelerate?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Hole In Header :-(
    sure would
  3. #3 Re: Hole In Header :-(
    I'm not even sure its worth welding.
    Or possible.
  4. #4 Re: Hole In Header :-(
    Bowie, MD
    Can i just header wrap it for now until i can order new headers?
  5. #5 Re: Hole In Header :-(
    yeah, that'd help.
  6. #6
    Bowie, MD
    Ok thanks
    Sent from my SGH-T989 using Tapatalk 2
  7. #7 Re: Hole In Header :-(
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    how did that happen?..
  8. #8 Re: Hole In Header :-(
    Bowie, MD
    Quote Originally Posted by 98buicksupercharged View Post
    From the looks of it.......the header was rubbing against the plastic piece of my fan?? and then through the plastic and the metal inside rubbed grinded it down im guessing.
  9. #9 Re: Hole In Header :-(
    Oct 2012
    Fort Wayne, Indiana
    lol im sorry. that is unfortunate
  10. #10 Re: Hole In Header :-(
    doesnt look like abrasion to me.
  11. #11 Re: Hole In Header :-(
    Antioch, IL
    why header wrap, get one of those exhaust band clamp things. rtv tighten down let dry walla it was never there
    2009 Challenger SRT8
    Expert at being gay.
  12. #12 Re: Hole In Header :-(
    SE Level Member oldsman105's Avatar
    Queens, New York
    get some quik steel. fill the hole and mold it around the damaged area. All good.
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  13. #13 Re: Hole In Header :-(
    Bowie, MD
    I will try all options. Thanks guys
  14. #14 Re: Hole In Header :-(
    I would just jb weld it
  15. #15 Re: Hole In Header :-(
    Nov 2011
    NY
    Not forward enough on the header pipe for an abrasion hole, looks liked a grinder or some sorta chemical. Doesn't really matter. I'd try the JB weld, if headers are off car you can push JB weld into the header pipe and flatten it on both sides, akin to a rivet. Then smooth it down prior to final hardening. JB weld is rated for 600*f but I don't know if the heating/cooling cycles will effect it.
    Good luck!
  16. #16 Re: Hole In Header :-(
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    those headers get hotter than 600* combustion temps range up to 1200* for a healthy car, hotter with no egr
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  17. #17
    Bowie, MD
    Yea the headers are hotter than all head
  18. #18 Re: Hole In Header :-(
    SWPA
    Could it be from battery acid?
  19. #19
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I know exactly how it happened
    I just noticed this problem on my car with my speed daddy headers.. It's being pushed up to the fan motor casing. I knew it would cause this... This why I'm ordering slim fans in like 10 min
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  20. #20
    Oct 2011
    MI
    How long have you had them on there?
  1. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  2. hole in VC
    By gtpinsc in forum General Tech Discussion
    Last Post: 01-23-2011, 10:50 AM
  3. so some a$$ hole wants to fight me...
    By mezzoni in forum The Rant Forum
    Last Post: 07-19-2010, 01:27 PM
  4. Could this be a hole in #1 piston?
    By guys00gtp in forum Off Topic Discussion
    Last Post: 06-24-2010, 03:27 PM
