Thread: Need some help on rebuild
Results 41 to 60 of 66
  1. #1 Re: Need some help on rebuild
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    Just reading this thread gives me nightmares about when I put my motor back in the car...
  2. #2 Re: Need some help on rebuild
    what did you torque them to?
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I torqued them to the recommended torque specs when I had the engine on the stand. I'm using the felpro intake manifold gaskets also.
    Sent from my SGH-T989 using Tapatalk 2
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  4. #4 Re: Need some help on rebuild
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Oh no, this sounds allll to familiar! When you torqued the Cam, did you re-use the same bolt? If so, did you clean/thread lock it good?
    I hate to say, I had this EXACT same sound then no start, came to find out the cam bolt backed it self out and now I'm on motor #2
    Take off the front cover and inspect your cam bolt and keyway, if you see any damage there, I feel your pain man lol.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
    Bowie, MD
    No I used a brand new cam bolt from zzp.
    I torqued the cam bolt on tight in an engine stand so there's no way it could have backed out and un screwed itself.
  6. #6 Re: Need some help on rebuild
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    ^^^^ So very correct.
    The bolt I think is 75lbs plus 90*. You know why it is plus 90* because most engine builders don't have torque wrenches that go to that high.
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    I torqued the cam bolt on tight in an engine stand so there's no way it could have backed out and unscrewed itself.
    This happened to one of our bonneville guys 95Nasta.(crazy engine build too not just a rebuild). I would pull the timing cover.
    97 Bonneville SE Not so much a 97 anymore
  7. #7 Re: Need some help on rebuild
    Tight? Spec is really fuggin tight.
  8. #8 Re: Need some help on rebuild
    Oct 2012
    New Jersey
    lol, exactly.
    Bowie, MD
    Mines goes up to 90
  10. #10 Re: Need some help on rebuild
    Nov 2009
    Central Jersey
    Mines goes up to 90
    Yeah not even close to enough for the cam bolt
    I'll be that guy. You are going to rip down the engine to find out whats wrong.
    Oct 2012
    New Jersey
    Quote Originally Posted by Nighthwk12 View Post
    I tried to say this nicely.
    how would a backed out cam bolt force all of the lifters open?
    Oct 2012
    New Jersey
    Still trying to figure that out myself, my cam bolt loosened and all my intake valves smashed the pistons.
  14. #14 Re: Need some help on rebuild
    May 2008
    Schuyler, NE
    Because it must have got out of time....it won't hold them all open at the same time though.
    Bowie, MD
    So I just self F it and went and bought a head gasket from auto zone and took the front head off to inspect. Check the entire head and everything seemed fine and the pistons also. I put the head back on and torques and soaked the lifters and added oil in the valleys this time.
    When I went to tighten down the rockers...it seemed as though this time the springs actually compressed lower this time than before and not all are depressed at the same time
    I need new lin gaskets and ive been busy with work so ill finish tommorow or Saturday.
    Also the rockers before had play which I think was causing the tapping but this time NONE has play.
  16. #16 Re: Need some help on rebuild
    Pennsylvania
    Update us with a new vid then.
    Bowie, MD
    Working on it. I have to finish putting everything together
  18. #18 Re: Need some help on rebuild
    Can't reuse your lim gasket?
    Bowie, MD
    Yea I'm reusing them but need new side tabs cuz the old ones got destroyed when I pulled them off.
    Bowie, MD
    Smh went and for some new lin gaskets and finished putting everything together and the car started with the same valve chatter so I turned it off and tried to start the car again but wouldn't start again Smh
  1. Top End Rebuild
    By MrPhotographer06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2011, 04:21 PM
  2. Top end rebuild
    By eganz84 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2011, 03:16 PM
  3. Done with my rebuild!!
    By Shang TI in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2011, 05:43 PM
  4. m90 rebuild
    By 91z in forum General Tech Discussion
    Last Post: 09-02-2010, 05:58 PM
  5. to rebuild or not to rebuild
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 04:14 PM
