Thread: Which head gaskets?
Results 1 to 17 of 17
  1. #1 Which head gaskets?
    GTX Level Member crbquist's Avatar
    Massachusetts
    What would be the best head gaskets for an L67 swapping to P&P L32 heads with stock valves? Should I go the cosmetic route, or just get some standard Fel-Pro gaskets off rockauto? If cosmetic, how thick of a gasket? Thanks
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: Which head gaskets?
    antioch ill
    cometic
  3. #3 Re: Which head gaskets?
    Feb 2009
    flintnasty MI
    Fail pros work fine up to 500whp.
    Get l36 ones.
  4. #4 Re: Which head gaskets?
    Fel Pro is my vote.
    Get l36 ones.
    This, theyre cheaper than l67 gaskets.
  6. #6 Re: Which head gaskets?
    Mar 2012
    NC
    I use FelPro permatorques on them. They hold up well. I also run head studs with them. Probably not necessary at my level but I plan on pulling the heads and I'll be damned if I'm buying another set of head bolts.
  7. #7 Re: Which head gaskets?
    May 2008
    Schuyler, NE
    Get Victor-Reinz from RA for the L36.
    Don't use Cometic.
    Massachusetts
    Forgot to mention that I'm going with arp studs over gm tty bolts. Should I still go with the fel-pro, even though intense recommends cosmetics? And why go L36 gaskets if the heads are L32? Wouldn't L32 gaskets be the better gasket?
    Massachusetts
    Get l36 ones.
    Why L36 over L67/L32 gaskets? Are they the same gasket just cheaper? Wouldn't the L67/32 gaskets be stronger?
  10. #10 Re: Which head gaskets?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by crbquist View Post
    i honestly think the L67 gaskets are just wrong or something, because they dont really make sense when you go to install them.
  11. #11 Re: Which head gaskets?
    Fel pro lists one gasket for L67. So you flip the gasket on the other side.
    Block and heads are identical except for the machined pocket for the fuel injector.
  12. #12 Re: Which head gaskets?
    Ohio
    lol guy...it is COMETIC....NOT COSMETIC
  13. #13 Re: Which head gaskets?
    Portland Oregon
    I've seen too many cometic's leak to warrant going with them unless you have a perfect mating surface on block and head. I used victor reinz gaskets when I rebuilt mine. That's what gm used. I've seen plenty of fel pro's go on just fine though
  14. #14 Re: Which head gaskets?
    Jul 2012
    Clayton,NC
    L36 felpro
    Massachusetts
    Quote Originally Posted by 99PGPGT View Post
    My bad. Dang tapatalk auto correct...
    Massachusetts
    So I guess L36 it is...
  17. #17 Re: Which head gaskets?
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    I can back this up... I have them sitting on the block, and just do not look right...
  1. $$$$$$ 4 Head gaskets
    By Octane in forum Engine
    Last Post: 01-06-2011, 12:54 AM
  2. Replacing head gaskets
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 12:11 AM
  3. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
  4. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
