Thread: 03 engine into 02 GP... Direct swap?
Results 1 to 12 of 12
  1. #1 03 engine into 02 GP... Direct swap?
    Jul 2012
    tulsa
    Will an 03 engine or engine/tranny combo swap directly into my 02 GP? I wouldnt think theres much difference. Will my PCM have any issues with it? I found an 03 with 86k miles complete engine for 650.00 Dont think ill pass that up. Sounds like a pretty good deal to me. Whats your input?
  2. #2 Re: 03 engine into 02 GP... Direct swap?
    it should swap right in, the only thing maybe the trans plugs, 03 they did some changes. its nothing you can work around.
    im sure BillBoost37 has a write up if you need to do this.
  3. #3 Re: 03 engine into 02 GP... Direct swap?
    If you did the complete swap, you need to use the 03 pcm, your 02 pcm wont work with the 03 trans.
  4. #4 Re: 03 engine into 02 GP... Direct swap?
    and the engine harness as well?
  5. #5 Re: 03 engine into 02 GP... Direct swap?
    Not sure on that part, I wouldnt think anything would change from 02-03, besides the way the pcm controls the trans.
  6. #6 Re: 03 engine into 02 GP... Direct swap?
    Jul 2012
    tulsa
    I wonder what changes they made on the tranny in 03 to make it.different? Not sure if I'm.getting the trans yet anyhow
    But good to hear it'll swap right in tho.
  7. #7 Re: 03 engine into 02 GP... Direct swap?
    Newer updated parts, hardened 4th gear, valve body/channel plate difference I believe.
  8. #8 Re: 03 engine into 02 GP... Direct swap?
    Jul 2012
    tulsa
    With those differences are they any stronger of a tranny than the previous years?
  9. #9 Re: 03 engine into 02 GP... Direct swap?
    Besides the 4th gear shaft, not really no.
    They all tend to have the same problems, just 03+ will likely never have a 4th gear failure.
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    One difference is that they put the gear selector switch inside the trans, vs bolted onto the top. The old style switch will still bolt on though, and you can use your stock harness with it. You would also need an 03 PCM (hardware) and a custom tune, starting with the 03 base cal. Not a bad swap, I ran an 03 trans in my 99 regal for 5 years or so, and the cars still going strong!
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  11. #11 Re: 03 engine into 02 GP... Direct swap?
    Feb 2009
    flintnasty MI
    you dont need any 'custom tune' but you would want to put the 03 file on.
  12. #12 Re: 03 engine into 02 GP... Direct swap?
    Oct 2012
    Pinckney, MI
    My bad, your correct.
    I was basing that statement off running an 03 trans with an older motor. If you have both an 03 Motor and Trans, you can just use a stock 03 PCM (Hardware and Cal).
    -Rob
  1. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  2. Direct injection
    By dert in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2011, 03:28 PM
  3. Replies: 0
    Last Post: 10-07-2011, 06:53 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
