Thread: Need help troubleshooting engine knock
Results 1 to 15 of 15
jonygtp Need help troubleshooting... 12-13-2012, 01:38 PM
Fivefingerdeathpunch Re: Need help troubleshooting... 12-13-2012, 02:05 PM
jonygtp Re: Need help troubleshooting... 12-13-2012, 02:19 PM
darkhorizon Re: Need help troubleshooting... 12-13-2012, 04:33 PM
dsmuts Re: Need help troubleshooting... 12-13-2012, 05:15 PM
REDCRAPGP Yup won't get much w/ a... 12-13-2012, 05:24 PM
jonygtp Re: Need help troubleshooting... 12-13-2012, 05:41 PM
Scottydoggs Re: Need help troubleshooting... 12-13-2012, 05:44 PM
dsmuts Re: Need help troubleshooting... 12-13-2012, 06:01 PM
Scottydoggs Re: Need help troubleshooting... 12-13-2012, 06:10 PM
dsmuts Re: Need help troubleshooting... 12-13-2012, 06:11 PM
REDCRAPGP Yup coolant in oil > boom !!... 12-13-2012, 06:16 PM
jonygtp Re: Need help troubleshooting... 12-13-2012, 09:34 PM
dsmuts Re: Need help troubleshooting... 12-13-2012, 09:48 PM
jonygtp Re: Need help troubleshooting... 12-13-2012, 11:54 PM
  1. #1 Need help troubleshooting engine knock
    Jul 2012
    tulsa
    Before I assume its a spun rod bearing I figure it would be wise to make sure before I go aimlessly tearing in to this thing.
    What kind of trouble shooting tips.can u gurus offer for tracking down the culprit?
  2. #2 Re: Need help troubleshooting engine knock
    I need a video to help you.
    I can't hear the sound through the computer screen.
  3. #3 Re: Need help troubleshooting engine knock
    Jul 2012
    tulsa
    I've never posted vid before. But ill see what I can do when I get home. I'm kicking around trying to sell it as. But not sure what its worth. Even tho its a GTX not sure if that helps much. I just spent two days putting in new LIM and UIM GASKETS Plus giving it a good tune up. Kinda disheartening really. But well see.
  4. #4 Re: Need help troubleshooting engine knock
    Feb 2009
    flintnasty MI
    rod knock after doing LIM gaskets is extremely common because people seem to get alot of water in the oil/cam valley and not flush it.
  5. #5 Re: Need help troubleshooting engine knock
    If the body on your car is immaculate with a knocking motor you'd be lucky to clear $1000
    Yup won't get much w/ a knocking motor. Most will just give you what the body itself is worth to them if they plan on replacing the motor.
    04 Comp G.
  7. #7 Re: Need help troubleshooting engine knock
    Jul 2012
    tulsa
    That's about how much I was thinking. It'd be better to part it out if I was to go that route. I tried to be careful when I pulled the intake off.
    I did get some in the oil but only a couple cups worth maybe. The initial startup only lasted maybe a minute because it was missing so bad.
    I then drained the oil but as bad as it looked I know it had to have been seeping in for a while. I think the damage was
    already done when I test drove it.
  8. #8 Re: Need help troubleshooting engine knock
    maybe you got the plug wires crossed up, that could be the misfire and the knocking sound maybe?
  9. #9 Re: Need help troubleshooting engine knock
    You didn't change the oil before start up? That's how you killed it.
  10. #10 Re: Need help troubleshooting engine knock
    i didn't change my oil after my lim job, but then again i also did not spill any coolant into the engine. it was still nice and clean, i idled the car for about 5 minutes, then checked the oil again, it was golden honey still.
  11. #11 Re: Need help troubleshooting engine knock
    Well that's because your magic lol
    Yup coolant in oil > boom !! I would however change your oil now in case it really isn't knock your feeling verify the plug wires are correct and such and make sure everything is connected. Then upload a video for us to see it'll help a lot more.
    04 Comp G.
  13. #13 Re: Need help troubleshooting engine knock
    Jul 2012
    tulsa
    I only idled the car for less than a minute with the bad oil in it. becuase it was misfiring so badly. I immedialtly changed it afterwards, ran it for a about four or five min then drained it again. Its not a bad spark wire or anything like that because it ran perfect, better than it ever had since i owned it,... for about ten min. lol
  14. #14 Re: Need help troubleshooting engine knock
    The starting it with coolant in the oil killed it in a hurry. Live and learn
  15. #15 Re: Need help troubleshooting engine knock
    Jul 2012
    tulsa
    I guess it is possible. Not gonna rule out stupidity. It's been about 6 yrs since I had done the LIM swap.
  1. Troubleshooting help. Engine won"t start
    By jimcarey78 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2011, 06:58 AM
  2. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. General Starting and Engine Troubleshooting Guide [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 12-15-2010, 12:24 PM
  5. Troubleshooting 2003 GP Engine knock
    By Shelligirl in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-07-2010, 08:24 AM
