Thread: Engine Issue/Noise.. w/Vid ::SOLVED::
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 76
  1. #1 Engine Issue/Noise.. w/Vid ::SOLVED::
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    My car has been perfectly fine no weird noises or sounds. today I came out of work at 5 (was fine on lunch) I remote start my car just a few moments before as I come out I hear this noise from this video kinda coming little bit I can rev it and it will come and go I just put this motor in not more than a few months ago and it's been running great I bought the car with a blown piston because of a clogged cat... this just looks like a fluke
    Im not really looking to fork out the cash for a new motor again. I Obviously I'm outside of the warranty already just figured I'd see what you guys thought I'm wondering if its main bearings.
    http://db.tt/ndma8Anh
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
    Oct 2011
    MI
    I don't know why it didn't post as a video instead of a download
    Oct 2011
    MI
    https://www.youtube.com/watch?v=VK_pXaSWfPQ
  4. #4 Re: Another Engine Issue.. With Video
    take the sc belt off first, then start it up, if it still makes noise, take the other belt off, run it, if its still there with no belts your kinda F'ed. hope for a bad pulley water pump a/c compressor idler,or tensioner. along them lines.
  5. #5 Re: Another Engine Issue.. With Video
    tennessee
    do you have an mps on your supercharger and are the bolts hitting the fusebox... i had the same noise and turns out my fusebox had come off the fender and was sitting on the snout
    Oct 2011
    MI
    Yeah I'm cooking some cheese brats and I was gunna pull the belts... I feel it might be bottom end as it gets louder when I pulled in the garage. I'm crossing my fingers but expecting the worst
    Oct 2011
    MI
    Quote Originally Posted by mskram1 View Post
    No I did a quick look over the second I heard the noise. Everything was clear of the belts.
    Oct 2011
    MI
    Found it. Looks like a bolt from the rear main cover came lose. It's rubbing on the flywheel.
    https://www.youtube.com/watch?v=n3TpDJpzH74
  9. #9 Re: Another Engine Issue.. With Video
    thats not good, you'll be separating your engine and trans at least. if not pull it or the trans out to fix that.
    Oct 2011
    MI
    Already started pulling the motor lol time for a set of headers
  11. #11 Re: Another Engine Issue.. With Video
    tennessee
    Quote Originally Posted by rperry435 View Post
    yeah i thought about that after my post lol
    Oct 2011
    MI
    Yeah it's a little odd we never took off the flywheel or even messed with the rear main seal cover during the swap. My brother and I put the engine in only 2 months/1200 miles ago so I'm glad it's just that bolt... I'll gladly pull it to not have to buy a whole new engine lol.
    Oct 2011
    MI
    Oct 2011
    MI
  15. #15 Re: Another Engine Issue.. With Video ::SOLVED::
    Looks normal.
    Oct 2011
    MI
    Lol I'm just glad the bolt didn't make its way out into one of the holes in the flywheel
    Oct 2011
    MI
    Motor is out and on the ground. I'm getting headers what else shod I do while it's out? I'm already doing a rear main seal since it is leaking slightly.
  18. #18 Re: Another Engine Issue.. With Video ::SOLVED::
    michigan
    Turbo, lower it, then sell it. Lol
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Well right now would be a good time to make sure all the gaskets have sealed up correctly . I know it's new but it still could have a leaky gasket . Just saying check the oil pan gasket really well . You'll thank me later if its bad
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
    Oct 2011
    MI
    I decided I'm changing the oil pan and gasket as well. Something I didn't do before I put it in the first time.
    I'm buying the ssautochrome headers..
    My cat was gutted and resonator removed... Everything was welded up... My question is do I need a downpipe?
  1. 2007 GXP water pump issue? Video attached
    By Cbierniat24 in forum 5.3L V8 (LS4)
    Last Post: 12-11-2011, 03:26 PM
  2. video of engine switching gears,look right?
    By spider4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2011, 02:57 PM
  3. FIXED!! Engine studder, tach drop, P1361 (video added)
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 04:14 PM
  4. Weird noise coming from my engine bay *with video's*
    By nawarkk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2010, 01:32 AM
  5. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
