Thread: Engine Issue/Noise.. w/Vid ::SOLVED::
Results 21 to 40 of 76
  1. #1 Re: Another Engine Issue.. With Video ::SOLVED::
    the headers should come with a DP, w/ or w/o a cat. or you can weld in a cat.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    What about the aluminum oil pan anyone know if I need anything else besides the pan and gasket?
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Engine Issue/Noise.. w/Video ::SOLVED::
    you dont use a gasket on the al pan, you use a rtv type sealer. and i think you need a new motor mount, as it bolts to the pan, instead of that bracket, may even need a different oil filter housing.
    someone posted up part #"s and cost a while back for all the parts new.
    Oct 2011
    MI
    I tracked down the part numbers
    Pan 12597244
    Pickup tube 24506437
    Mount bracket 10345562
    not sure on pricing I get a discount ill have to check in Monday. I snow someone said it's not much more than the steel pan so why not I like the idea of no sealant
    Oct 2011
    MI
    I assume I'll need a pickup tube gasket..? Nvm I found it
    Oct 2011
    MI
    Okay just to be sure this will work just fine for my 04 GTP? lol
  7. #7 Re: Engine Issue/Noise.. w/Video ::SOLVED::
    Yeah..it'll work fine. I've done it a bunch of times.
    On that rear main. Do the rear engine cover gasket. I'm assuming that's one of the bolts that backed out. They are in with such low torque that I see that gasket seeping more commonly than the rear main itself. As long as the cover is off, obviously you do the rear main, but the cover gasket, I like to increase torque a ft lb or two and add some locktite to the bolts.
    Oct 2011
    MI
    Yeah a rear cover bolt is what backed out... I'm replacing the cover gasket and rear main because there is some seepage. I Ordered the parts for my aluminum pan as well.
    one question I did have is... I want to replace the flex pipe (I just purchased the speed daddy headers $216 shipped when I called them and ill have them by thursday) I guess they leak? ... Anyways what size flex do I need? I'm going to order one from ZZP today with some various other things like a shift kit and dev6
  9. #9 Re: Engine Issue/Noise.. w/Video ::SOLVED::
    3" ...
    It's not that it leaks out of the box, but the single wall is noisy...you hear ticking. It's not a leak, just loud. The dual wall are much quieter.
    Oct 2011
    MI
    I don't recall having an issue with the ssautochrome headers flex section but I just figured it needed to be done... Hmm how loud are we talking? lol
  11. #11 Re: Engine Issue/Noise.. w/Video ::SOLVED::
    Not very and if it bugs you..use header wrap on the flex.
    Oct 2011
    MI
    Doing a shift kit how many gallons will I need of dex6? Does the Zzp kit come with a pan gasket?
  13. #13 Re: Engine Issue/Noise.. w/Video ::SOLVED::
    7 to 8 quarts of fluid, reuse the factory gasket.
    and in another thread people were saying the zzp shift kit sucks. weak parts.
    Oct 2011
    MI
    Hmm anyone have a recommendation? I was just ordering some things from figured it was easiest to get from them. What parts could break?
  15. #15 Re: Engine Issue/Noise.. w/Video ::SOLVED::
    this thread talks about the zzp kit. page 3 http://www.grandprixforums.net/fiero-hell-3-71113.html
    Oct 2011
    MI
    Soo wbody kit?
  17. #17 Re: Engine Issue/Noise.. w/Video ::SOLVED::
    i have a shift kit, but bought it in the trans already, so i cant say what i have. but people seem to like the transgo kit i think its called.
    Oct 2011
    MI
    I've had a transgo in my GTA loved it. I'll find one of those
  19. #19 Re: Engine Issue/Noise.. w/Video ::SOLVED::
    The zzp kit is either plastic spacers or metal spacers. You can make your own Zzp kit for much less.
    Transgo is a good kit. Comes with extras.
    Oct 2011
    MI
    Yay some goodies
  1. 2007 GXP water pump issue? Video attached
    By Cbierniat24 in forum 5.3L V8 (LS4)
    Last Post: 12-11-2011, 03:26 PM
  2. video of engine switching gears,look right?
    By spider4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2011, 02:57 PM
  3. FIXED!! Engine studder, tach drop, P1361 (video added)
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 04:14 PM
  4. Weird noise coming from my engine bay *with video's*
    By nawarkk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2010, 01:32 AM
  5. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
