Thread: misfire dead
Results 1 to 20 of 25
  1. #1 misfire dead
    GTP Level Member 2001goldGTP's Avatar
    california
    So I was driving home Wednesday the car misfired for a few seconds the check engine light flashed and it died. The battery has 12.8 volts, the motor has fuel pressure, I have spark at the coils and the end of the plug wires. The car cranks and sometimes stumbles like its going to start but never does. What the hell is wrong with it.
    I have done no mods to the engine for about 18 months now, its the same L67 that came with the car. 95K on the clock
    xp'd
  2. #2 Re: misfire dead
    You blew it up.
  3. #3 Re: misfire dead
    May 2011
    Kansas City
    ^ what this feeg said
    Reptile Tune (SOLD)
  4. #4 Re: misfire dead
    california
    hard to believe that happened at 2100 rpms
    xp'd
  5. #5 Re: misfire dead
    Bro, I toasted a motor with cruise control on.
    Go yank the plugs out.
    Or..better yet, check the oil for metalliclovelyness.
  6. #6 Re: misfire dead
    california
    i have blown up another grand prix, its sounded find except for the mis, i thought a plug wire had failed, or even a coil pack, then it just died, cranks strong with no odd noises at all. it just doesnt turn over
    xp'd
  7. #7 Re: misfire dead
    Chipped piston.
    Ring or something else wrapped around crank?
    No compression on multiple cylinders?
    yeah.
    It's possible.
    Pull the plugs and check them.
    That's easy.
  8. #8 Re: misfire dead
    california
    i will pull the plugs, but im sure it has compression in all cylinders
    xp'd
  9. #9 Re: misfire dead
    Well do a compression test too.
    That's easy.
  10. #10 Re: misfire dead
    california
    i have a scope to, I will scope the damn thing, I just haven been home since i had to push the bit#h home. I was hoping to have an easier place to start looking
    xp'd
  11. #11 Re: misfire dead
    super clogged cat? wishful thinking?
  12. #12 Re: misfire dead
    Since it is XP'd I'm sure it has catless headers...wanna bet?
  13. #13 Re: misfire dead
    California though
  14. #14 Re: misfire dead
    california
    Cat has 18k on it, like i said it was running fine right up till it stopped lmao
    xp'd
  15. #15 Re: misfire dead
    california
    I know this is old but i finally got the car going. I have had the car back up and running now since the first of the year. Here was the issue
    I replaced the chain and tensionor 20K ago and it broke. I am running 105# crow valve springs. Well seems like that was a mistake, so now i have a double roller on there. had to fit a coolant leak for what ever reason as well, and now the car runs just fine. knock on wood, all seems to be well with the car, plenty of power still. If anyone reads this and has a stock chain on 105# springs, my advice, get a double roller
    xp'd
  16. #16 Re: misfire dead
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Looks more like you tensioner grenaded.
    97 Bonneville SE Not so much a 97 anymore
  17. #17 Re: misfire dead
    california
    Yeah, i needed a comma in there to break that up, the chain slack just simply let the car jump time enough not to start or run or do anything helpful
    xp'd
  18. #18 Re: misfire dead
    Nov 2009
    Central Jersey
    Very cool it was only that.
  19. #19 Re: misfire dead
    The right side would be pulling the left around. And there wasn't enough to cause the chain to come off the gears, right?
    Good catch, was that the stock tensioner as well?
  20. #20 Re: misfire dead
    california
    Yeah the chain stayed on the gears for the most part. The tensionor would bind up the chain to the point it jumped. The chain and tensionor where stock oem, i changed when i installed my cam.
    xp'd
  1. ECM dead or not dead
    By Egibb12 in forum General Tech Discussion
    Last Post: 08-11-2012, 10:57 AM
  2. 97 GTP DIC dead... Help please
    By Prixer97 in forum Audio, Security & Visual Electronics
    Last Post: 06-29-2012, 02:28 AM
  3. GP Dead
    By trailshredder in forum General Tech Discussion
    Last Post: 01-11-2011, 12:30 PM
  4. I think my GTP is dead. :-(
    By nickbuol in forum Off Topic Discussion
    Last Post: 11-25-2010, 01:13 AM
  5. Hello I am the Dead-Man
    By iamthedeadman in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:31 PM
