Thread: Heater blower control mudle
Results 1 to 3 of 3
  1. #1 Heater blower control mudle
    Sep 2011
    Canada
    Well, I'm only getting the fan at high speed and the temp doesn't seem to work no matter how high I put it up or down. Worst of all, I'm getting very little heat. My engine temperature is normal, coolant is good and I have no coolant light or anything.
    I'm guessing it's the heater blower control module. Since it has auto A/C and dual climate control the cheapest I've seen the part for is $154.00. The AC Delco part number is 15-8756.
    Does anyone know if there's a cheaper alternative or do I have to bite the bullet and buy one of these? I have a 2000 Grand Prix GTP.
  2. #2 Re: Heater blower control mudle
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    you could run a wire to it and put it on a switch
    __________________________________________________ __________________________________________________ ______________________stage 3 zzp heads,sd headers,ss m90 kit,3in cat back,AEM wide band,cai,evap egr rear 02 delete.
  3. #3 Re: Heater blower control mudle
    flushing and filling your heater core. that could be the lack of heat problem.
    and you need a blower resistor, not the module most likely.
  1. a/c heater blower
    By buschegt in forum General Tech Discussion
    Last Post: 09-25-2012, 05:34 AM
  2. Replies: 0
    Last Post: 02-18-2012, 01:47 PM
  3. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  4. Heater Blower
    By stratojet in forum General Tech Discussion
    Last Post: 03-22-2009, 09:58 PM
