Thread: What belt for 3.5-3.4 setup
Results 1 to 20 of 21
  1. #1 What belt for 3.5-3.4 setup
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys I've read through the forums and there was a thread that said to get size 660 for a 3.5 setup with no ic on a grand prix. So i did and the belt is way to long. Longer then stock so I need to know what belt to use with a 3.4/3.5 setup on a 99 grand prix with no ic. Thank you!
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: What belt for 3.5-3.4 setup
    SE Level Member therealtoddster's Avatar
    Oct 2016
    You used to be able to run the stock belt if you compensate with installing a larger idler pulley.
    Sent from my SM-G920R4 using Tapatalk
  3. #3 Re: What belt for 3.5-3.4 setup
    Oct 2015
    Ya I'd rather just get the right belt lol
  4. #4 Re: What belt for 3.5-3.4 setup
    i ran the stock belt on the 3.4 for years, it works just fine.
  5. #5 Re: What belt for 3.5-3.4 setup
    Oct 2015
    I'm pretty sure it's slipping occasionly I'm getting belt squeal and on some runs I'll be getting 8.5-9 lbs of boost and then on other 7.5lb
  6. #6 Re: What belt for 3.5-3.4 setup
    i made 12 in the winter 10 in summer on a 3.4 and stock belt, yours is not slipping unless your belt is shot.
    if you really want a shorter belt, drive to a parts store and ask if you can test fit a few belts, figure out what stock is, try one a 1/2 inch shorter, most stores will let you do this. ive yet to find one that wont. most of the time they ask you leave your drivers lic for collateral. how i got my belt for the 3.0 and 3.2 pulleys.
  7. #7 Re: What belt for 3.5-3.4 setup
    Oct 2015
    That's probably what I'll have to do should be to hard just to find a belt ever so slightly smaller then stock. Why do you see so much of a psi difference from weather is it the density of the colder air. I knew it fluctuated but I never thought there would be that much of a difference
  8. #8 Re: What belt for 3.5-3.4 setup
    cold air is denser. so more psi.
    tell the parts guy what your doing, he can figure out how long your belt is, and then give you a shorter one. all them numbers on the belt add up to it size.
  9. #9 Re: What belt for 3.5-3.4 setup
    Oct 2015
    Ok thanks Scotty. Also off topic do you know if I can wire my new wideband up to replace the stock narrowband o2?
  10. #10 Re: What belt for 3.5-3.4 setup
    no, you need the upstream o2, add a bung install the wb in it.
  11. #11 Re: What belt for 3.5-3.4 setup
    Oct 2015
    O ok. I watched this video on YouTube and the guy wired it up to replace the narrowband but it was on a miata and his o2 only had one wire. It would have been awesome if you could do that haha. Also my original plan was to just wire it up to my aftermarket head unit just because it's so easy but on the instructions it says not to for some reason. So what would be the best place?
  12. #12 Re: What belt for 3.5-3.4 setup
    people put in the vent, the cubby, or a dash pod or a A pillar pod.
  13. #13 Re: What belt for 3.5-3.4 setup
    Oct 2015
    No I mean where should i splice in for power to the gauge?
  14. #14 Re: What belt for 3.5-3.4 setup
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by suitercrew View Post
    There's a unused plug that's already routed to the fuse box on its own fuse in our cars it's behind the glove box. You can buy zzp's drop down harness to plug right into it or just cut the plug off the one on your car and splice into it. There's 3 wires a ground, constant power, and an accessory wire which is where I hooked my aeroforce to so the gauge shuts off when you turn the car off.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  15. #15 Re: What belt for 3.5-3.4 setup
    the fuse box is my first choice lol
    get a add a fuse, put it in the wiper fuse and now you got key on power.
  16. #16 Re: What belt for 3.5-3.4 setup
    Omaha, NE
    Here is ZZP's belt size chart with gates belt part numbers.
    Applications:
    667 - Gen 5 blower stock belt GTP/GS/SS supercharged with stock 3.8" pulley (67 1/4" -1708mm)
    663 - Gen 3 blower stock belt GTP/GS/SS supercharged with stock 3.8" pulley (66 7/8")
    660 - GTP/GS/SS supercharged with 3.3 - 3.7" pulley (66 3/4")
    658 - GTP/GS/SS supercharged with 3.2 - 3.6" pulley (66 3/8" - 1687mm)
    653 - GTP/GS/SS supercharged with 3.1 - 3.5" pulley (65 7/8")
    650 - GTP/GS/SS supercharged with 2.8 - 3.1" pulley (65 1/2")
    645 - GTP/GS/SS supercharged with 2.6 - 2.8" pulley
    716 - Bonneville SSEi, Park Ave, or Riviera with a 3.4" pulley
    721 - Bonneville SSEi, Park Ave, or Riviera with stock supercharger pulley (72 5/8" 1845mm)
    (Riviera/Bonneville/Park Ave use same length belts)
    Stage 2 or 3 Intercooler
    685 - 3.3"+
    680 - 2.90" - 3.20"
    675 - 2.6" - 2.8"
    Short Stack intercooler
    675 - 3.5" pulley
    672 - 3.3"-3.4" pulley
    670 - 3.2" pulley
    667 - 3.0" pulley
    Accessory belts
    915 - Stock accessory belt for Series II '99-03 (works with either UD WP pulley or OD alt pulley but not both) (2340mm)
    919 - 99-03 Accessory belt with WP UD pulley 92 3/8"
    923 - Accessory belt for Series II '99-03 with UD WP pulley and alt UD pulley (2360mm)
    905 - Stock accessory belt for 04+ Grand Prix/ 04+ Monte Carlo/ Impala
    935 - Stock accessory belt for 97/98 -or- 04+ Monte with Alt relocation kit (94" - 2367mm)
    938 - Accessory belt for 97/98 with both underdrive pulleys (2400mm)
    SS M90 supercharger kit for L36
    970 - SS M90 for 97/98
    955 - SS M90 for 99+ 4.0"- 4.2" pulley
    950 - SS M90 for 99+ 3.8"- 4.0" pulley
    947 - SS M90 for 99+ 3.5"-3.8" pulley
    Meziere electric water pump
    875 - 99-03 accessory belt with Meziere electric water pump
    864 - 04+ accessory belt with Meziere electric water pump
    895 - 97/98 with Meziere electric water pump
  17. #17 Re: What belt for 3.5-3.4 setup
    Oct 2015
    Ya see that's the list I went off of before and I got the 660 belt for my 3.5. 660 is actually bigger then stock by a lot too.
  18. #18 Re: What belt for 3.5-3.4 setup
    Omaha, NE
    Where'd you get your stock belt? How long is it?
    Don't take this the wrong way, but you've got it routed correctly?
  19. #19 Re: What belt for 3.5-3.4 setup
    Oct 2015
    Haha ya I got it routed correctly. The stock belt was got from advance auto as the stock belt part #. It is stock belt length.
  20. #20 Re: What belt for 3.5-3.4 setup
    Kemmerer, Wyoming
    looking at the above list of what belt size to use with the specific pulley, a 660 is smaller than stock, as it should be. the stock length for a gen 3 car is a 663, if you look, you will see. This is the list I have been using:
    http://www.grandprixforums.net/threa...elt-size-chart
    One thing I have noticed is that if a belt wrap kit is used, a longer belt also needs to be used, but so far I haven't seen any information on what belt size to use with the specific pulley and a belt wrap kit.
  1. dual belt setup, l67 head
    By SnowTh1ef in forum For Sale - Parts
    Last Post: 04-06-2015, 06:50 PM
  2. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  3. the stock supercharger belt will work on a 3.4 setup right?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2010, 11:36 AM
  4. S/C Belt for I/C setup?
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2009, 09:48 PM
