Thread: Running on full boost!!! AAAHH!!!
Results 1 to 20 of 22
  1. #1 Running on full boost!!! AAAHH!!!
    Sep 2012
    Charlotte, MI
    Ok folks. . . have a real dillema. . . When I start the car the boost bypass immediately goes into full boost - its not flopping around like it should be. I just replaced the solenoid within the past few months, and to test it I checked the ground for continuity and it clicked - and I replaced the perfectly good new one with the good used one. Same thing. It keeps going into full boost and it is stalling out my wifes car and she now hates the world and the car .
    All of the vacuum lines are plugged in, and I cant see where there would be an issue unless its internal. . . HELP!!!
    (2001 3.8L GTP Topswap)
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Have you tried replacing the valve itself? Maybe the diaphragm is torn. Does it move at all when you start the car or rev the engine?
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Running on full boost!!! AAAHH!!!
    Sep 2012
    Charlotte, MI
    dear heavens thanks for responding. Yes the valve goes from completely relaxed (all the way down), and immediately flops all the way to full boost when it starts and will not bob up and down like its supposed to.
    I am freaking out maaaan. . . .super troopers style
  4. #4 Re: Running on full boost!!! AAAHH!!!
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    replace that and your car will work again
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
    May 2011
    United States
    Flopped up is open, flopped down is closed. It should flop up when ypu start the car and flop down when you rev it good. It operates of vacuum.
    Sent from my Droid
  6. #6 Re: Running on full boost!!! AAAHH!!!
    Sep 2012
    Charlotte, MI
    i thought it was boost on demand.. . its supposed to flop up, which it does. . . but this flops all the way up on full boost. ever since I have had the car it would bob up and down and as you accelerate it goes to full boost. this immediately goes to full boost and subsequently stalls out at start up.
    May 2011
    United States
    If its moving, its working. Up is bypassing boost down it is not bypassing.
    Sent from my Droid
  8. #8 Re: Running on full boost!!! AAAHH!!!
    Sep 2012
    Charlotte, MI
    so it is supposed to be full boost all the time?
    Its supposed to go from its resting position to full boost with no fluctuation afterward? That is what its doing - its on full bypass
  9. #9 Re: Running on full boost!!! AAAHH!!!
    Mar 2012
    Dallas
    if it is not down(sitting on the SC stop block) then you are not full boost, it is open
  10. #10 Re: Running on full boost!!! AAAHH!!!
    Sep 2012
    Charlotte, MI
    so replace the boost bypass valve? and things should be good to go?
  11. #11 Re: Running on full boost!!! AAAHH!!!
    Mar 2012
    Dallas
    if the valve is staying closed yes.
    May 2011
    United States
    This is how it should work.
    http://www.youtube.com/watch?nomobile=1&v=EA7J_qIurAU
    Sent from my Droid
  13. #13 Re: Running on full boost!!! AAAHH!!!
    Sep 2012
    Charlotte, MI
    yeah its not cool like the video. . . . it just goes to full vacuum right off the bat and stalls out
  14. #14 Re: Running on full boost!!! AAAHH!!!
    does it run if you hold it where it should be?
  15. #15 Re: Running on full boost!!! AAAHH!!!
    Sep 2012
    Charlotte, MI
    No sir, it does not. It starts, the bypass immediately goes to full boost, and then it stalls out.
    I removed the bypass and I don't see anything wrong on the exterior - the diaphragm looks fine . . .
  16. #16 Re: Running on full boost!!! AAAHH!!!
    Mar 2012
    Dallas
    did you hold the valve open? which would be holding the lever up
    May 2011
    United States
    I doubt the bypass valve is causing ypur problem. It should run fine even if you are always running full boost.
    Sent from my Droid
  18. #18 Re: Running on full boost!!! AAAHH!!!
    How are you making boost at idle even with the BBV closed?
    Also whats a GTP top swap mean?
  19. #19 Re: Running on full boost!!! AAAHH!!!
    Sep 2012
    Charlotte, MI
    The block is a stock 3.8 naturally aspirated. the top (heads, intake,) were removed and a supercharger, underdrive pulley, GTP heads and injectors were added. a 2007 transmission and ECM were added too.
    SO, yeah to answer your question - I dont know - that was essentially my question and why I am here trying to figure out situation because I dont know.
  20. #20 Re: Running on full boost!!! AAAHH!!!
    a 2007 ECM is untunable and wouldn't work with your combination.
    It wouldn't know what to do with your injectors, have the wrong cal for your MAF, would want to see a TAC instead of an IAC/TPS.
    It'd either command too much timing and run too lean OR transmission wouldnt know when to shift.
    So, are you sure?
  1. not getting full boost
    By 02grandprixgtp in forum General Grand Prix Discussion
    Last Post: 09-22-2012, 10:43 PM
  2. Not building full boost
    By Wsmccoy in forum Turbo
    Last Post: 05-21-2012, 06:43 AM
  3. I have full boost now.
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 10:52 AM
  4. not getting full boost?
    By Standby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 05:43 PM
  5. Did the LIM this weekend, not getting full boost, and getting hot... wtf?
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 10:18 AM
