Thread: Belt shredded, pulley problem?
Results 1 to 20 of 24
  1. #1 Belt shredded, pulley problem?
    SE Level Member mckillin's Avatar
    Ontario, Canada
    Hey guys,
    2004 GTP 158km, new belt (dayco) installed in december. new power steering pump and rack done about 2 months ago... last night i heard pieces of belt flinging around... Popped the hooded, main serp belt inside had pieces coming off, basically lost inside *towards engine* of 1 whole rib backing. Picked up a new belt today (goodyear) and installed it... tensioner seems good and is tight, but i thought it might be a loose pulley causing this.. all pulleys seem pretty snug except little play found on power steering pulley.. Is this normal? I took it back to the clown that did the job and he says alittle play is normal it needs it? His guess is it was caused by the belt not being installed on properly (which he had off last)... I'm not buying it, so just looking for help and advice if anyone can help that would be great! its running fine and looks good just looking for what might have caused this belt to go so soon... Thanks in advanced
  2. #2 Re: Belt shredded, pulley problem?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    lol there should be no play at all on your pulleys, wtf? they only thing that should move is your tensioners. dude messed something up, either the PS pulley or the pump shaft.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #3 Re: Belt shredded, pulley problem?
    p/s pump pulley should be tight. no side to side play at all.
  4. #4 Re: Belt shredded, pulley problem?
    Ontario, Canada
  5. #5 Re: Belt shredded, pulley problem?
    Ontario, Canada
    thanks guys... that what i figured, i dont trust this clown @ all to touch my car again so I'm going to need to figure it out and get it fixed before i chew up another belt so... got a pic of the side of the pulley and looks like a bolt is missing? looks like an allen key then threads behind it? any ideas or help on what to do? do i need to pull the pump and try and reseat the pulley or something?
    thanks
  6. #6 Re: Belt shredded, pulley problem?
    are you talking about the p/s pump? its press on and pull off only, nothing else hold it on.
    the threads in the end of the shaft is for the puller.
    post the pic you took, lol
  7. #7 Re: Belt shredded, pulley problem?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    I got $20 that says he beat the pulley off with a hammer then beat it back on the new pump the same way.
    GPONA #1 Cyber Bully
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Check for play and look to see if any pulleys are put of line or wobbling when the engine is running. (keep your hands clear when running obviously)
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  9. #9 Re: Belt shredded, pulley problem?
    Ontario, Canada
    https://www.dropbox.com/sh/mrgah31s1ia6ojc/mht1pLn95x
    took a video of it running, everything seems okay nothing is way way out or whobbling... but when I get the pulley off the p/s pump... its moves and makes some noise, added the videos to dropbox link above... its obviously too loose just wondering best way to fix this properly...
    thanks guys
  10. #10 Re: Belt shredded, pulley problem?
    that should not be that loose at all, it should be nice and tight.
  11. #11 Re: Belt shredded, pulley problem?
    Ontario, Canada
    okay so whats best way about this? i need to pull p/s pump off and press pulley on more?
  12. #12 Re: Belt shredded, pulley problem?
    the new pump comes with not pulley, you take the old one off and put it on the new pump.
    you need a power steering pulley puller. they sell them at the parts store.
    they may even have them for rental. not like you really pay, just leave a deposit for the tool, and get a full refund when you return it.
    and heres how you use it. you dont need a vise.
  13. #13 Re: Belt shredded, pulley problem?
    Ontario, Canada
    awesome man! thanks for the help... i'm going to work @ this lol pretty sure i can get the rental unit local then i'm going to get the pulley off and see wtf he did and get it back on tight, thanks again, will update with my progress!
  14. #14 Re: Belt shredded, pulley problem?
    and you need to remove the pump to get the pulley off.
    jack the car up, remove pass side tire, remove the 2 lines off the pump from the wheel well, one is a clamp on a hose, the other is a line nut into the pump. have a bucket to catch the fluid, as its all coming out when you take the lines off.
    then go back up top, if you have a your coolant over flow tank by the strut and belts remove it, you can take the alt off too, lets you see better when putting it back on, not much but it helps.
    now theres a hole in the pulley, with a 3 inch extension and a socket, go through the hole at the 12 and 6 o clock position are the bolts, remove them and the pumps off, rocking the engine forward helps it clear its way out.
    then remove the pulley, and put it on the new pump, then install the new pump, add new fluid, run the car for a minute, turn the wheels back and fourth a few times, then shut it off, and check the fluid level, fill if needed.
    one of them long thin transmission funnels works good for filling the pump too, just go slow and watch the tank level, very easy to over fill it.
  15. #15 Re: Belt shredded, pulley problem?
    you need a new pump, its the shaft moving like that, not the pulley. you need to re use your pulley on the new pump, thats why you need the puller tool.
  16. #16 Re: Belt shredded, pulley problem?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    ^^^^ And if you do all that, you might as well pull the tensioner and replace the coolant elbows.
    May 2011
    United States
    ^^^^^ And if you do all that, you might as well get the aluminum coolant elbows.
    Sent from my Droid
  18. #18 Re: Belt shredded, pulley problem?
    Ontario, Canada
    Found the bill, I paid $75 for a dormer from the parts store.... wonder what the warranty is like on that *****
  19. #19 Re: Belt shredded, pulley problem?
    Ontario, Canada
    thanks man... seems easy enough, should of just did it myself from the get-go. paid buddy to do the rack and pump back in august, what a kicker haha
  20. #20 Re: Belt shredded, pulley problem?
    some parts have 30 days, but up to 90 days. depends on who you got it from and if it was new or rebuilt.
  1. pulley belt from zzp
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 03:09 PM
