Thread: Engine noise
Results 1 to 15 of 15
  1. #1 Engine noise
    SE Level Member Mrjcuhh's Avatar
    Oct 2012
    Pompano beach, Florida
    I have a 1999 L67 and was wondering if the winding noise that the car is making is normal because its supercharged or is it a bearing in the supercharger that needs to be replaced?? Does anyone know of a solution to the problem or is this normal? Some feedback would be greatly appreciated!
  2. #2 Re: Engine noise
    I live here. TLSheff's Avatar
  3. #3 Re: Engine noise
    Take a Saturday or whenever you have a day off and you can fix it with basic tools
    Pre-order INTENSE-Racing.com: INTENSE Supercharger Coupler Change Kit
    $40.00 + shipping
    Buy some good latex gloves, the old fluid stinks something fierce and if you let it soak in, the lady in your life will run for a couple days. Take my word on it, been there, dealt with that. Use rubber gloves.
    The rest in in the instructions, if you need a video, YouTube is your friend. Coupler replacement is common, no worries. Easy fix
  4. #4 Re: Engine noise
    Oct 2012
    I'm not quite sure that's the same noise I'm talking about.. I'll have to upload a video, but its almost like the same sound a worn out power steering would make
  5. #5 Re: Engine noise
    Oct 2012
    But I do appreciate the response
  6. #6 Re: Engine noise
    do you hear it at a idle, then it increases with rpm's, driving or in park?
    it sounds like the power steering pump. hows your steering? still easy to turn when in park, when you turn the wheels does it whine more, parked, at a idle?
  7. #7 Re: Engine noise
    Oct 2012
    Yes I hear it at idle and does increase with rpms but steering seems perfect, a mechanic told me its just because the car is supercharged but I'm not convinced... i know the supercharger does make noise but should only really make that winding noise when in boost?? Correct me if I'm wrong
  8. #8 Re: Engine noise
    antioch ill
    no you will hear it at idle if you have an intake on it or headers
  9. #9 Re: Engine noise
    Oct 2012
    I will try to do the turning while in park and see if the noises change
  10. #10 Re: Engine noise
    Oct 2012
    Just took this vid.. It's that awkward noise kind of like a drone/winding noise
    Supercharger noise? - YouTube
  11. #11 Re: Engine noise
    if you are all stock, stock air box as well, you will hardly hear the sc even when in boost. open cone on stock ( what i have) and all i hear is air sucking into the engine, (at idle) and with cone you hear the inside of the engine as well. at idle.
    no whining at all at idle.
  12. #12 Re: Engine noise
    ok, take the sc belt off, then start it up listen to hear if its stillthere, if so then remove the other belt, and start it if is gone, its a pulley or the alt or even water pump, witht belts off check all your pulleys for side to side play, and smooth spinning.
    so im saying it sounds like one of your idler, tentioner, or alt, or water pump is making noise.
  13. #13 Re: Engine noise
    Oct 2012
    Cool I'll check it out and get back to you
  14. #14 Re: Engine noise
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    sounds like mine did when the ps pump was going out would make that noise until i took off the belt then it went away
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  15. #15 Re: Engine noise
    Oct 2012
    Yeah I thought it was ps at one point also
  1. engine noise
    By carlover89 in forum General Tech Discussion
    Last Post: 01-04-2012, 03:31 PM
  2. Engine noise
    By gerhardt02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 09:49 PM
  3. Engine noise
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2010, 10:03 PM
  4. 06 GP L32 Engine noise
    By GeeBee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 11:59 AM
  5. Engine Noise
    By Damojo2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2009, 11:16 AM
