I will try to do the turning while in park and see if the noises change
ok, take the sc belt off, then start it up listen to hear if its stillthere, if so then remove the other belt, and start it if is gone, its a pulley or the alt or even water pump, witht belts off check all your pulleys for side to side play, and smooth spinning.
so im saying it sounds like one of your idler, tentioner, or alt, or water pump is making noise.
