Thread: What is wrong with my supercharger?
Results 1 to 6 of 6
  1. #1 What is wrong with my supercharger?
    canada
    My 98 GTP supercharger is rattling at stop lights and searching indicates bad coupler.
    However the supercharger is also causing my engine to loose power - where sometimes I can barely make it up a hill. I thought it was my transmission not downshifting and was planning for a rebuild but the previous couple of days I took the SC belt off and it drives perfect only lacking a little bit of power due to no SC.
    The SC pulley seem to spin nicely - are my SC rotors bad? The SC makes a loud rattling unnatural sound every time I turn the engine off as if things are clunking into each other. Are there other SC parts that can cause power loss? I am not sure why the engine RPM stays under 2000 sometimes when I hit the gas even if I floor it and the boost indicator is coming on.
    Am I ok to drive with the belt off for a long while?
    Thanks.
  2. #2 Re: What is wrong with my supercharger?
    NE Ohio
    yes, you can drive with the belt off.
    that definately sounds like a bad coupler. id just rebuild the whole thing though personally.
  3. #3 Re: What is wrong with my supercharger?
    SE Level Member SLO-6's Avatar
    Aug 2008
    Texas
    Yea deffinatley look in too rebuilding it. One of my pullies just started acting up havent looked into which one been a little preoccupied...
    Eaton M90 S/C, Thrasher Engineering CAI (soon a FWI By: TDC RACING, MSD Wires. ZZP 3'' Stainless Catback Exhaust, Northstar TB KIT, ZZP 3.4 Pully Swap
  4. #4 Re: What is wrong with my supercharger?
    Feb 2008
    Well, it sounds to me like you might have a couple problems. The rattling both when the engine is running and after it shuts off sounds like a coupler or bearings that need to be changed. Like previously suggested it might be worth either rebuilding or getting a rebuilt S/C.
    On the second thing where you say you can't go up past 2000 rpm, if fixing the S/C doesn't fix that problem, I would suggest that you might be having a fuel problem (weak fuel pump). I had the same problem as you did (turned out to be a FP for me). You can check this out by getting a fuel pressure tester. Fuel system pressure should be between 48-55 PSI. Good luck and let us know how it goes
  5. #5 Re: What is wrong with my supercharger?
    SE Level Member LaCabra's Avatar
    mission, tx
    Where is a good place to get my S/C rebuilt... or can i do it myself
  6. #6 Re: What is wrong with my supercharger?
    Barksdale AFB, LA
    The blower isn't hard to take apart or put together. Taking it apart will tell you what components need to be replaced, which will determine how expensive it is.
    2009 Subaru Impreza WRX STI
  1. What the hell is wrong with me....
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 09-14-2008, 04:27 PM
  2. Cold air gone wrong
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2008, 03:37 PM
  3. whats wrong with the se?
    By blazedgp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2008, 09:20 AM
  4. wrong offset bullitt wheels
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 01:22 PM
  5. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
