what can i use to clean the rotors without ruining the coat of anti friction and can i use brake clean to do the case
Super clean.
It totally works and doesnt damage the coating. Unless its already failing.
Just apply some onto the rotor, then onto the rag and scrub. Rinse with water when done and you'll have some factory looking rotors.
