looks like you forgot to look up your codes.....
next step would be the throttle position sensor. .P0068 - Google Search
and a maf sensor P0101 - Google Search
check your wires on the plug side for cracks or bare wire showing, if you see this, change the pig tail.
you can also un plug the maf to see if it runs better. if it runs better unplugged, your maf is bad 90% of the time. best place for a maf is the junk yard, as they cost some coin new, 40 used most of the time, if you dont pocket it on the way out the yard. wink wink.
if it does run you can drive it like that, but take it easy on it, aka no beating on it.
you should also have a maf fuse, or one that works it, check all fuses, under the hood and in the car.
