Thread: lim torque
Results 1 to 19 of 19
  1. #1 lim torque
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    used search bar couldnt find the correct tighteing order for the bolts on the lim. anyone have a diagram showing what order to go in?
  2. #2 Re: lim torque
    use the "centre out" theory.
  3. #3 Re: lim torque
    SE Level Member simongtp's Avatar
    Jun 2010
    Longview, TX
    inner most 4 then outter most 4
    go back to the others on the inside then the others on the outside
    i always do it in the shape of an x kinda like a tire where you go across from bolt to bolt
    torque to 11 foot pounds
    simon
  4. #4 Re: lim torque
    Sep 2012
    bridgeport,NY
    gotcha thanx a bunch
  5. #5 Re: lim torque
    Just go tight.
    Even at 11 ft lbs the bolts can break with ease.
  6. #6 Re: lim torque
    Just go tight.
    Been there done that.
  7. #7 Re: lim torque
    Sep 2012
    bridgeport,NY
    so go snug then a quarter turn
  8. #8 Re: lim torque
    dont forget the thread sealant for the lim bolts as well.
  9. #9 Re: lim torque
    Sep 2012
    bridgeport,NY
    thread sealant required or a precaution
  10. #10 Re: lim torque
    required.
    Otherwise oil will wick up the bolts.
  11. #11 Re: lim torque
    Just go tight.
    Honestly? Wow.. I've reused these bolts time after time, have found torque specs of 11ft lbs and 13ft lbs. For the aluminum gaskets I use 15ft lbs. Never heard of this issue before.
    Although I understand how a Canadian might have trouble with pounds vs meters.. lol
  12. #12 Re: lim torque
    Mar 2012
    NC
    I've never replaced them...just used thread sealant. Doesn't mean they can't break, just saying I've never broken one.
  13. #13 Re: lim torque
    Quote Originally Posted by hitman92499 View Post
    If you haven't, Brian hasn't and I haven't.. It can't be easy to break one..lol
  14. #14 Re: lim torque
    use a torque wrench?
    I tried once.
  15. #15 Re: lim torque
    Ever break a harmonic balancer bolt?
  16. #16 Re: lim torque
    No, just the balancer itself.
    Ohio
    I've never broken an lim bolt and I always use a torque wrench. Never used thread sealant either.
    I just go by the torque spec chart from wherever I got that from haha
  18. #18 Re: lim torque
    Sep 2012
    bridgeport,NY
    in/lbs or ft/lbs
    Ft/lbs
    04 Comp G.
  1. Torque app
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 07-08-2012, 01:20 PM
  2. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  3. Lug Nut Torque
    By hacket in forum Tires & Wheels
    Last Post: 04-10-2010, 07:04 AM
  4. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
  5. torque..?
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2008, 11:13 PM
