used search bar couldnt find the correct tighteing order for the bolts on the lim. anyone have a diagram showing what order to go in?
use the "centre out" theory.
inner most 4 then outter most 4
go back to the others on the inside then the others on the outside
i always do it in the shape of an x kinda like a tire where you go across from bolt to bolt
torque to 11 foot pounds
simon
Honestly? Wow.. I've reused these bolts time after time, have found torque specs of 11ft lbs and 13ft lbs. For the aluminum gaskets I use 15ft lbs. Never heard of this issue before.
Although I understand how a Canadian might have trouble with pounds vs meters.. lol
required.
Otherwise oil will wick up the bolts.
I've never replaced them...just used thread sealant. Doesn't mean they can't break, just saying I've never broken one.
use a torque wrench?
I tried once.
No, just the balancer itself.
