Thread: Pretty sure the engine is toast :(
Results 1 to 6 of 6
  1. #1 Pretty sure the engine is toast :(
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Ouch... Good thing replacement L67's are cheap.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Pretty sure the engine is toast :(
    The Boss Iceman6669's Avatar
    Jun 2011
    What happens when you rev it?
    2011 F-150 Yote powered
  4. #4 Re: Pretty sure the engine is toast :(
    post a vid of it reved up, then just let the throttle drop,( like bring it to 3,000 rpm, and let off the gas) and holding the idle higher. to rule out a flex plate.
  5. #5 Re: Pretty sure the engine is toast :(
    There is oil in cylinder #4 I pulled the plug cuz that was showing the mis expecting to find a smashed plug but the plug was just coated in oil.
  6. #6 Re: Pretty sure the engine is toast :(
  1. I'd say it's toast
    By jwjones in forum Off Topic Discussion
    Last Post: 01-12-2012, 07:30 AM
  2. Yeah toast!
    By afallucco in forum Off Topic Discussion
    Last Post: 01-15-2011, 08:20 PM
  3. Are my cluthes toast? FU firestone!!!
    By Pepino in forum General Tech Discussion
    Last Post: 05-25-2010, 11:19 AM
  4. 3rd gear toast
    By izup69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 07:03 AM
  5. Last of a dying breed! A Toast.
    By Toofastgs in forum Off Topic Discussion
    Last Post: 05-03-2009, 07:17 PM
