this will be a multi part question. I am trying to remove the bank 1 valve cover on my series II gtp.
SO far I have uncoupled the passenger side motor mount, removed the Supercharger belt, tensioner pulley, the other pulley next to it, removed the two bolts that sat underneath it and the threads that went into the block. I have also removed the ignition control module, coil packs, plug wires and harness plug.
By the look of it there is now nothing that should be holding this ignition control module/tensioner/motor mount bracket on. . . is there a bolt I am missing.
It looks like there might be a bolt that runs through the tensioner thru the block. . . *?* help!
