Thread: Seeping coolant around injector
Results 1 to 10 of 10
  1. #1 Seeping coolant around injector
    Florida
    Just out of habit i popped the hood not too long ago after a brief 20min drive and i notice around cyl.#3 injector(the middle one in the front bank) had a small puddle of coolant around it.What would be the cause of this? Im hoping its not LIM gasket failure or somethin too serious. Here are some pics too:
  2. #2 Re: Seeping coolant around injector
    '04's still had plastic LIM gaskets from the factory.
    Looks like you got some gaskets to change, brutha.
  3. #3 Re: Seeping coolant around injector
    Florida
    AHH fml.Oh well good thing i still have those brand new zzp metal LIM gaskets layin around.
  4. #4 Re: Seeping coolant around injector
    I live here. TLSheff's Avatar
    Yup yup, that's what mine did before I changed my gaskets. They weren't horrible but some were cracked pretty good and they were in need of changing. Do it before you have more problems, and get new o-rings for the injectors when you pull them out.
  5. #5 Re: Seeping coolant around injector
    Florida
    Also have new injector o-rings layin around.Well once i get 2 days back to back off days from work i will be tackling this project.Thanks guys.
  6. #6 Re: Seeping coolant around injector
    Only o-rings that really need replaced are the base ones, the tops are meh @ best.
    And the plastic retainer clips aren't necessary either.
  7. #7 Re: Seeping coolant around injector
    ^ This, when I replaced mine I carefully pulled the whole fuel rail with injectors out and just replaced the bottom o-rings... snapped off like half of the retainers but they weren't needed, use some petro-jelly to put them back in tho, lube really helps them seat back down in the hole properly, otherwise they get stuck.
    btw... your a pervert, stop giggling!
  8. #8 Re: Seeping coolant around injector
    Florida
    Lol wow TLS,well its funny i read your comment normally then after i read stop giggling i looked back a sentence and saw what you refered to.But anyway thanks for the tips,and i do remember about a month ago I made an attempt to pull my fuel rail/injectors but they were tough and didnt budge.Besides the 4 fuel rail bolts and injector harnesses and other things that would prevent the injectors from comin out?
  9. #9 Re: Seeping coolant around injector
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    they are tricky. dont know about the 04+ but mine had a nut on top of the SC
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  10. #10 Re: Seeping coolant around injector
    My catalog only shows 4 nuts holding the rails in place. Better check and make sure nothing is holding them in place, there is a MAP Sensor bracket on the back side, it maybe attached or in the way.
    Otherwise consider an 04 is now 9 years old, if they haven't been removed since being built they're not gonna play nice, you have to convince them Just be careful, don't break anything. Mine were a pain on my 99, but they listened after some work.
  1. do i have a clogged injector or a bad coolant temp sensor
    By athalflife3 in forum General Tech Discussion
    Last Post: 07-09-2013, 02:14 AM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. 04 gtp injector.
    By Toms04compg in forum General Tech Discussion
    Last Post: 04-18-2012, 11:34 AM
  4. Injector ?
    By CrazyGuy03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 10:43 PM
