Thread: Leaky Valve Cover Recall?
Results 1 to 9 of 9
  1. #1 Leaky Valve Cover Recall?
    Sep 2012
    hamper
    When I start my car I see smoke, and I look it my valve cover is leaking did GM have a recall on this, I don't wanna phone in and look like a knob. - Thanks - Mel
  2. #2 Re: Leaky Valve Cover Recall?
    the recall is for the front cover only, call any Gm dealer with your vin # and they can tell you if the recall has been done or not to your car.
  3. #3 Re: Leaky Valve Cover Recall?
    Only the GTP model had a recall for the valve cover and I believe it was for the front or rear only.
    I would clean the oil up asap if its smoking and then replace the valve cover gaskets, your car is at risk of starting on fire.
  4. #4 Re: Leaky Valve Cover Recall?
    Kansas
    Yes.
    Dec 2010
    DMV
    Yes GM had a recall on this issue.
    They will fix it for you as long as your vin comes up in the system as one of the affected models. Call your local dealership and find out.
  6. #6 Re: Leaky Valve Cover Recall?
    Kansas
    Lol two different answers. Just call the dealer, and find out.
  7. #7 Re: Leaky Valve Cover Recall?
    its only the front cover. for s/c engines only. i called GM to find out if mine was done or not.
  8. #8 Re: Leaky Valve Cover Recall?
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    Like all said it is the front valve cover gasket and grommets they also replace the front wire holder with reg wireholders to keep the wires away from the manifolds and oil
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  9. #9 Re: Leaky Valve Cover Recall?
    SE Level Member destroyer85golf's Avatar
    Aug 2012
    Hillsdale Illinois
    Dashboard register your car with GM and it will come up with any active recalls
    2000 GTP daytona 500
  1. Leaky valve cover gaskets...which ones to buy?
    By rell2005 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2012, 02:42 AM
  2. Valve Cover recall
    By blktalon456 in forum General Tech Discussion
    Last Post: 02-26-2010, 01:00 PM
  3. Valve cover gasket Recall
    By Dexter in forum Off Topic Discussion
    Last Post: 01-17-2010, 12:55 AM
  4. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
  5. recall notice for valve cover gaskets!
    By nutcase in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2008, 02:06 PM
