Thread: Evap leak and surging in 4th
Results 1 to 16 of 16
  1. #1 Re: Evap leak and surging in 4th
    Banned
    Jun 2012
    Sacramento CA
    When you say ... you've tried premium mobil fuel. Does that mean that you typically don't run Mobil or don't run premium?
    If you answer that you don't run premium, the issue is between the seat and steering wheel. Likely you hurt the motor.
    If no to the above, then change the plugs and wires. You are probably running some crappy plugs like Bosch platinums that get destroyed in our waste spark environment.
    I'm changing your title... Cause you don't need a mechanic to solve this one. Likely it's straight forward enough thatmy 17 year old neighbor could solve it in ...HER sleep.
    Completely disrespects and belittles new member...
    Quote Originally Posted by vtechkiller View Post
    will do ill run the codes next time I'm at autozone
    Bends over and takes it.
    OP the bouncing as said before could be the TCC and/or solenoid. If the car is under warranty get it in there ASAP...
    You can look for the Evap leak by following the lines around the engine bay. The Evap canister is bolted to the same plate the MAP sensor is on, and is connected by a red plug.
  2. #2 Re: Evap leak and surging in 4th
    Quote Originally Posted by fry626 View Post
    Is that how you read it? That's not how I wrote it. Maybe you need to hang out with me to understand how I would have put tone and inflection on that blurb.
    His title was in all caps as if he was screaming for help from a mechanic. I'm pretty well versed in these cars and am not a mechanic. My mechanic buddy calls me when he has a question on this kind of car though. What hsi titls would get from veteran members is skipped by. It's the "OH GAWD MY CAR SUCKS, HELP ME!!!!!!" that most vets roll their eyes at and skip until they are bored. By changing his title, he'll get a lot more views and insight. It's odd...it's reverse psycho though.
    Experience (and searching if done) will tell us this issue is 85-90% likely to be the plugs. These motors run well for so long, that people often forget them. Then parts slingers often sell the guy the Bosch plug, which is known to break down super quick in the waste spark ignition system. Poof.. month or two in you have surging, maybe misfires, etc.
  3. #3 Re: Evap leak and surging in 4th
    May 2012
    Brandon, Manitoba, Canada
    Hi sorry for revisiting this but my 2000 GTP is doing exactly the same as described in the original thread. Surges/bucks soon as it shifts into 4th, most noticable when slightly accelerating up hill. I am a GM mechanic and i cannot figure this one out on my own. I have replaced the plugs with proper AC delco platinums, replaced both the mass air and throttle position sensors, replaced the air and fuel filters and i always run premium fuel. I have driven the car with the GM scan tool on 4 separate occasions and cannot see obvious data that will direct me to the problem. Did the car in this thread get corrected? Any help would be greatly appreciated.
  1. Clunking beats the Mechanics
    By Burley117 in forum Brakes/Suspension/Chassis
    Last Post: 03-21-2012, 11:06 PM
  2. scammed by mechanics, please help
    By DSMissed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2011, 07:57 AM
  3. Any Diesel Mechanics out there???
    By kenizzle36 in forum Off Topic Discussion
    Last Post: 04-28-2011, 09:52 AM
  4. mechanics on here
    By JarenSTi in forum Off Topic Discussion
    Last Post: 10-06-2010, 11:24 AM
  5. Sloppy Mechanics Dyno Day Allentown Pa Sunday 10-25-09
    By geforcextreme in forum Northeast
    Last Post: 10-14-2009, 10:32 PM
