Thread: Quick question (water pump)
Results 1 to 20 of 35
  1. #1 Quick question (water pump)
    SE Level Member cgator's Avatar
    tampa , florida
    im having a little problem with my 97 gtp it seems i have no coolant going to either one of my hoses neither upper or lower and when i hit the throttle the lower hose collapse's .... i changed thermostat and flushed radiator and i know radiator is not clogged cause during flush water came out both ends .... now when i drive the car stays at about 180* but as soon as i stop it climbs up to about 240* almost in the red zone ... could this be a bad waterpump ?
    thank you ahead of time for your answers
    1997 pontiac grand prix GTP
  2. #2 Re: Quick question (water pump)
    tampa , florida
    nobody has any idea as to what this could be?
  3. #3 Re: Quick question (water pump)
    Barksdale AFB, LA
    You waited an hour... Give it time.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Quick question (water pump)
    tampa , florida
    sorry im just trying to figure out what i need to get for tomorrow i only get 1 day off a month and tomorrow is it ... and i need to get this problem fixed since this is my daily driver .... i didnt mean to be jumpy
  5. #5 Re: Quick question (water pump)
    Oklahoma
    Plus you double posted.
  6. #6 Re: Quick question (water pump)
    tampa , florida
    Wow I thought forums were to help each other not critisize each other..... Sorry if I only waited an hour and sorry I double posted... If you didn't notice I am new and wasn't sure where to post that question so I posted it in the 2 most appropriate places... I guess this forum isn't what its all cracked out to be maybe I should find one with people who actually can help people other than critisize them..... So on that note thanks for nothing but critisism and wasteing my time
  7. #7 Re: Quick question (water pump)
    tampa , florida
  8. #8 Re: Quick question (water pump)
    Oklahoma
    We're not criticizing you. Our job as a community, mine in particular as an Admin is to make sure things run smoothly so that everyone can get help. Part of that comes from the rules that govern the site and you'll find those rules in nearly every forum you participate in, we are not unique in that regard.
    You have to keep in mind that every one here participates as volunteers I guess you would say, giving of their time and expertise. We make NO guarantees to response times. Furthermore, if you had not double posted you would have possibly seen that I replied to one of your posts, but you were watching this thread and thats why we have rules like no double posting. It makes it confusing which thread to respond to and makes it difficult for you to track the replies.
    Im sorry you feel you were being criticised, but I assure you that was not the case. Im sorry you feel you have to vacate the community because someone points out mistakes made but then again if this your normal response to things it may be the best action to take.
  9. #9 Re: Quick question (water pump)
    tampa , florida
    Yea I understand that I'm not trying to sound like a jerk but the last forum I joined was a bmw m3 forum and I had response's immediately. I do understand your point though and I appologize for sounding like a jerk. I just needed some info rather quickly and kinda expected it. So I usually am not this way I just barely have time for anything so once again I appologize
  10. #10 Re: Quick question (water pump)
    tampa , florida
  11. #11 Re: Quick question (water pump)
    Oklahoma
    No problem at all and thank you for posting that. You are welcome here. Ive never been on or visited the M3 forums but if you got near instant replies, thats really good but is by no means the norm as automotive forums go. I belong to a software forum that has over 700,000 registered members and nearly 70,000 of them are active and I still dont get anywhere near that kind of response to any questions I post there.
    We are a little slow at times perhaps be we make up for it in the quality of responses you get and the community help and friendship you will find here. Its a fairly tight knit group, something you dont always find on larger forums.
  12. #12 Re: Quick question (water pump)
    tampa , florida
    yea i appreciate your understanding and on that note i found my problem it is not the water pump i have a crack in that plastic elbow that goes from the water pump to the head ... now does anybody know how that peice comes out so that i can replace it (i will wait for an answer this time .. lol)
  13. #13 Re: Quick question (water pump)
    Barksdale AFB, LA
  14. #14 Re: Quick question (water pump)
    tampa , florida
    its not letting me view it sabrewings it brings me to a login page
  15. #15 Re: Quick question (water pump)
    Barksdale AFB, LA
    Quote Originally Posted by cgator View Post
    That really is weird. Maybe one of our admins changed the rules and now you have to be a member.
    Well, if you want to register we have a how to on replacing the coolant elbows.
  16. #16 Re: Quick question (water pump)
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I just looked at the write-up and I'm not so sure about it.
    Basically
    Move the coolant overflow bottle out of the way
    Remove the s/c and serpintine belts.
    remove the alternator
    remove the alternator bracket (bracket doubles as coolant passage way)
    replace both elbows
    clean the holes the elbows came out of.
    Put vaseline on the elbow orings insert each into the alternator bracket
    Reverse the process.
    ZZ Performance.
    get both elbows
    Anything more specific, please ask.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  17. #17 Re: Quick question (water pump)
    St Louis MO
    http://www.cpaclubgp.com/misc/lim-gasket.html
    Have a look at this video, I'm pretty sure you will see the coolant elbows covered somewhere in there.
    2010 Camaro SS LS3
  18. #18 Re: Quick question (water pump)
    Barksdale AFB, LA
    Quote Originally Posted by IndeedSS View Post
    What are you not sure about? He uses the same process you did with more detail (showing every bolt).
  19. #19 Re: Quick question (water pump)
    tampa , florida
    ok from what i understand i have a 97 so i only have one of those coolant elbows
  20. #20 Re: Quick question (water pump)
    Feb 2008
    Yes, the '97's only have one elbow. I found out the hard way by looking for the second one for about an hour before reading up.
  1. Quick question (water pump)
    By cgator in forum General Tech Discussion
    Last Post: 09-21-2008, 10:13 PM
  2. Quick question on Air Induction CAI
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2008, 01:26 AM
  3. Quick question about tuning
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-21-2008, 09:49 AM
  4. 1.9 rr's 105#'s, water pump, lim, alls kinds of stuff..
    By kyle99gtp in forum General Tech Discussion
    Last Post: 05-12-2008, 11:39 PM
  5. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
