Originally Posted by matt5112 Why did you change the injectors? You're no where near the point where you need larger ones. If you put the stock ones back in you can drive it, but I wouldn't go WOT. Stock timing table is aggressive and will probably knock quite a bit on a 3.4, 3.6 being the recommended pulley. However scan and find out. I havent changed anything yet, I just wanted to know if I did change them for a 3.4 setup if I could drive it before a tune The car is my DD so I cant afford to have it sit at all
Forum Rules
