I can't even think of what this could be. 04 comp g, plog and dp, intake..lately it's been having this issue when I want to go from coasting to light throttle, or light throttle to slightly more, it bogs down and refuses to shift, I have to get pretty far into the throttle to get it to downshift.
It's not like it's revving up but not catching, for example at times I'll be coasting down a road and reaching the bottom of a shallow incline so I will give very light throttle to maintain speed. You know the little kick of power you feel going from full coast to light throttle, almost like a downshift but not as much and only a small rpm change... That doesnt happen.
In fact when I give it the gas, most of the time the rpms rise slightly then drop back down with very little increase of power. Then I give it more and the same thing I have to get pretty far into the throttle to get a downshift or any real response. Before, I could just tap the gas and feel the car wake up from coasting.
Once the car bogged down when I tried to accelerate so that my head went forward a little... And this morning I went slow through a short construction zone and at the end I put a little gas on to get up to speed from like 15 mph trying to get to the speed limit of 35 and the car bogged down so bad when I touched the gas I thought it was gunna stall.
Heavy throttle it acts normal, good power and good boost, normal driving shifts are excellent.
Just cleaned tb and maf, did seafoam, changed plugs, did the downpipe, tranny fluid and filter, this was happening before I did all that, though.
