Thread: ZZPerformance High Velocity Throttle Body
Results 1 to 20 of 29
  1. #1 Re: ZZPerformance High Velocity Throttle Body
    The maf stays stock but it is seeing more air and messing with it. If you don't believe me go out and pull your screen out of your tb and check your ft's. They will be way off and cause KR
  2. #2 Re: ZZPerformance High Velocity Throttle Body
    Banned
    Jun 2012
    Sacramento CA
    Removing the screen can cause turbulence across the sensor... completely different. Porting a stock TB and keeping the stock MAF will do absolutely nothing to make the car run worse.
  3. #3 Re: ZZPerformance High Velocity Throttle Body
    The screen doesn't cause turbulence it smooths the air out.
  1. high velocity intake insert
    By RyanL in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2010, 10:16 PM
  2. HV3 High Velocity intake insert
    By Kerker48 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2009, 12:10 PM
