Thread: oily substance on SC gasket, snout side
Results 1 to 20 of 25
  1. #1 oily substance on SC gasket, snout side
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    i have the garlock gasket from zzp, it has recently turned wet, and has a oily residue on it and the portion of the LIM it does not cover. it feels like oil , but has no smell. if it was SC oil i would definitely be able to smell that.
    are there other areas that could leak this?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: oily substance on SC gasket, snout side
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    snap a picture
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  3. #3 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
  4. #4 Re: oily substance on SC gasket, snout side
    Dec 2008
    Cedar Rapids, IA
    hmm, thats odd..ig its time to pull the sc back off and get a new gasket and re-seal it.
  5. #5 Re: oily substance on SC gasket, snout side
    When was the last time it was apart?
  6. #6 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
    when i had the top end rebuilt back in may
  7. #7 Re: oily substance on SC gasket, snout side
    gars-leak
  8. #8 Re: oily substance on SC gasket, snout side
    Are you missing any sc oil? Or antifreeze?
  9. #9 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
    well i drained coolant to take off my TB spacer, then went to fill it back up after i was done, took off radiator cap and coolant burped out and was full to the top. i dont get that, why would coolant burp out when i drained some?
    as for SC oil, like i said it is odorless, SC oil is horrible smelling even just a drop will stink out the room.
  10. #10 Re: oily substance on SC gasket, snout side
    New sc oil isn't bad. Have you checked it at all?
  11. #11 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
    last month, it was full. i will double check tomorrow.
  12. #12 Re: oily substance on SC gasket, snout side
    last month it wasn't leaking though right?
  13. #13 Re: oily substance on SC gasket, snout side
    i kid you not, and i know this makes no sense at all, but after i did my coupler, i put it all back together, and the gasket under the snout where the bolt goes straight down broke off and fell into the abyss. i put it back together with out any gasket as i looked at the parts and said to myself, whys there a gasket here? it was leaking s/c fluid as soon as i started the car. i took the bolt out, coated the threads with rtv and stuck it back in, instant leak stop.
    ive been told theres no reason for that bolt to leak, but it did.
    so i think its worth looking at.
  14. #14 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
    appreciate that, i just went and got, 5qts of mobil 1 and mobil1 filter, fram fuel filter, and a (FelPro) supercharger gasket. i will change all that and coat that bolt with RTV like you say and see if it fixes my problem.
    not that the other stuff will "fix" my problem, just maintenance up keep.
    have not had a chance to check for low SC oil, been raining out here all day.
  15. #15 Re: oily substance on SC gasket, snout side
    Scott..only reason I can make for that leak is oil seeping up the bolt threads while in boost. From the PCV etc.
  16. #16 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
    doing the gasket change today. checked SC oil, it is still full. so it has not leaked.
    did fuel filter, very easy, other than getting gas all down my arm and side of my face(residual in lines and filter), bunch of black fuel came out the gas tank side of the filter. stained the ground with a small mound of dirt too lol.
    so bill, being you think it is PCV leakage under boost, is that the cause of defective PCV? i have a new valve in the SC case and a breather on front valve cover.
  17. #17 Re: oily substance on SC gasket, snout side
    if you want to see more crap, fill the fuel filter up with gas again, shake it up, then dump it again. even more dirt will come out.
  18. #18 Re: oily substance on SC gasket, snout side
    No, I don't think it's defective. If you pull a charger, you almost always find oily residue in the LIM. Especially in an NA motor. It is dumped into the LIM and since it has recesses..it pools.
    I think it's normal oil vapor that is being pushed up. At least that's my suggestion, because that gasket does absolutely nothing that I've ever found by being under the snout, except keeping the charger flat and level on the LIM.
  19. #19 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
    okay, thanks scott and bill. i will take a few pics of the gasket change and leakage areas. and a few pics of the port job on my SC.
    never got a chance to take pics, was in a hurry to get the car running again after it blew the rear head gasket(poor workmanship on engine reassembly by previous owner)
    it broke down in my school parking lot at UTI thankfully. they my only time to work on it was a hour a day before class. it was up there for like 3 months, while i collected money and worked the heads at my machine shop, then reassembly.
  20. #20 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
  1. 4t65e side cover gasket $29.99 Advance auto
    By davevanoke in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-25-2013, 03:24 PM
  2. Overheating -- blown LIM side gasket?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2012, 06:09 PM
  3. 1997 4T60E side cover gasket
    By wrpfctr7 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 09-02-2011, 06:28 PM
  4. whats milky and oily and causes a car to just stop running
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 09-04-2010, 12:54 AM
