Thread: oily substance on SC gasket, snout side
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #1 Re: oily substance on SC gasket, snout side
    I see two things here. That the gasket wasn't holding at the pcv and that was leaking oil across the gasket. It definately worked like a Bounty paper towel (at least if you believe the commercials). Looks to have seeped all the way around and the only place it was visible was at the snout, where the POS was the thinest.
    Here we see that there is hardly any gasket under the snout based on the way it was cut. This likely led to some pressure pushing the oil outward in the snout area. My thoughts.. inferior gasket. Fel Pro MS95744
  2. #2 Re: oily substance on SC gasket, snout side
    quality gasket.
    Unsure why they still sell them.
  3. #3 Re: oily substance on SC gasket, snout side
    Why are you running a valve cover breather?
  4. #4 Re: oily substance on SC gasket, snout side
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    was on the car when i bought it. kept it to keep crank case pressures down.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  5. #5 Re: oily substance on SC gasket, snout side
    Mar 2012
    Dallas
    yeah, i got the felpro on there now. think i had boost/vac leak with that gasket too?
    edit: car still seems to be doing this.. it will rev up like the AC is kicking on, but the rpm gauge doesnt really move much, like a load got put on the engine, during idle. the lights will dim down usually and slowly brighten back up. thought maybe i had a small vac leak, gasket change didnt fix this weird problem.
    Thinking maybe a sticking IAC valve on my TB? all that was cleaned when i had the top end apart during the rebuild. it was quite dirty.
  1. 4t65e side cover gasket $29.99 Advance auto
    By davevanoke in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-25-2013, 03:24 PM
  2. Overheating -- blown LIM side gasket?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2012, 06:09 PM
  3. 1997 4T60E side cover gasket
    By wrpfctr7 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 09-02-2011, 06:28 PM
  4. whats milky and oily and causes a car to just stop running
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 09-04-2010, 12:54 AM
